lohelle
Tue Aug 28, 2012 10:14 pm
Can a version 6 node sync with a version 5.8 node? Or do I have to schedule downtime to upgrade to 6.0 ?
Wed Aug 29, 2012 10:48 am
The procedure will not require the downtime at all. You just need to install 6.0 on top of 5.8 (you can install it on node2 only after the synchronization process will be finished).
kmax
Wed Aug 29, 2012 3:13 pm
Just wanted to let you know did the upgrade this morning and thus far everything is fine. Was actually surprised by how fast the HA targets synced.
lohelle
Wed Aug 29, 2012 7:12 pm
Did my upgrade now. All good so far.
btw: Is it possible to enable ALUA without recreating the target (or switching parter, to the same partner)
It would be GREAT to be able to suspend one or multiple target(s), do some settings (ALUA, sync channels etc) and then just do a quick-sync to be up and running again. Now we have to do a full sync, right?
Bohdan (staff)
Fri Aug 31, 2012 1:30 pm
lohelle wrote: Now we have to do a full sync, right?
In this version yes.
Removing a partner, then adding the partner with ALUA enabled -> requires full sync.
