Stop Full Synchronization
kkit
Tue Apr 25, 2023 12:07 am
I have an urgent problem.
After I rebooted one node, StarWind went into full sync. The performance is extremely degraded and I can barely start up VMs.
I made sure to shut down all VMs and put one Node into maintenance mode.
How can I stop full sync? It says it will take 15 days!
Tue Apr 25, 2023 7:33 am
Shutting down ALL VMs is not needed. Please see the restart procedure at https://knowledgebase.starwindsoftware. ... installed/. Please make sure to follow the restart procedure.
Please note that it is unlikely to run into full sync during one node restart.
1. What is the storage configuration (RAID level, if StarWind VSAN for vSphere, how storage is connected to the VM)?
2. What is the HA device size?
Workarounds.
1. Reduce sync priority with the script haSyncPriority (C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell).
2. Review storage configuration.
3. Remove caches if any are used. See more at https://knowledgebase.starwindsoftware. ... -l1-cache/ and https://knowledgebase.starwindsoftware. ... dance/661/
4. Make sure StarWind VSAN is up-to-date.
5. Make sure not to terminate the service in the future.
For quicker response time, please consider switching to commercial licenses with the support plan that works best for you. See more at https://www.starwindsoftware.com/support
kkit
Tue Apr 25, 2023 10:42 am
Thanks Yaroslav.
I will do a full sync over the weekend and see. I will also update to the latest StarWind Version.
I have two more questions:
- You wrote that there is a script to limit sync speed. Which script exactly is for bandwidth limitation?
- I have read that StarWind supports Sync Journal. Do you have a documentation to enable this feature
EDIT: Found this document: https://knowledgebase.starwindsoftware. ... a-devices/
Do you have a powershell manual?
Thanks again
kkit
Tue Apr 25, 2023 1:05 pm
Greetings,
By setting it to 5% you can limit the sync speed so that VMs are likely to get more I/O and the performance hit of full sync on slow storage should become moderate.
kkit
Tue Apr 25, 2023 2:04 pm
Okay, but which of the ps scripts does that?
Tue Apr 25, 2023 2:13 pm
Please see the path and script name above.
Let me know if you have questions on tailoring the script.
kkit
Tue Apr 25, 2023 2:24 pm
yaroslav (staff) wrote:Please see the path and script name above.
Apologies, missed it! Will check it out, thanks much!
Tue Apr 25, 2023 3:09 pm
You are welcome :)
kkit
Thu May 04, 2023 2:30 pm
yaroslav (staff) wrote:You are welcome :)
Hello Yaroslav,
just wanted to give you the feedback that everything went fine, sync took 16 hours for 71TB over 2x 10GBit Fiber connection.
Update of StarWind went also fine :)
Best wishes
Eren
Thu May 04, 2023 5:10 pm
Eren,
Thanks a lot for your update :)
