Ivan Ischenko
  • Ivan Ischenko
  • May 9, 2025
Fault Tolerance: Definition, Use Cases and Benefits
IT outages cost $5,600/min on average. Downtime isn’t just a tech problem – it’s a business risk. Our new article breaks down the fundamentals of Fault Tolerance and how it helps protect your operations from unexpected failures.
Didier Van Hoye
  • Didier Van Hoye
  • May 7, 2025
How to Unlock BitLocker-Encrypted Azure VM Disks in a Recovery VM
If your Azure VM is down and the OS disk is encrypted with BitLocker, this guide is for you. Learn how to mount the disk to a recovery #VM and unlock it securely using PowerShell and Azure Key Vault.
Brandon Lee
  • Brandon Lee
  • May 6, 2025
Windows Recovery Environment (RE): Full 2025 Overview
Let’s be honest – nobody likes dealing with a Windows system that won’t boot. But when it happens, knowing how to use Windows Recovery Environment (WinRE) can save you hours of stress.
  • Dmytro Malynka
  • May 2, 2025
Automated Backup: How It Works & Why You Need It
Manual backups are unreliable and time-consuming. Learn how to automate your backups and protect your data from disasters.
Ivan Ischenko
  • Ivan Ischenko
  • April 30, 2025
Application Virtualization: A Comprehensive Guide
From easier software updates to better security, application virtualization brings a lot to the table. But it’s not without its challenges. Find out everything you need to know in our detailed article.
Marius Sandbu
  • Marius Sandbu
  • April 29, 2025
Private Infrastructure for LLMs: A Guide to Running AI Locally
Public cloud LLMs are powerful, but they don’t always meet security and compliance needs. Learn from our detailed guide how to deploy Large Language Models (LLMs) on your own infrastructure and create a private AI environment – from GPU requirements to scaling for multiple users.
  • Dmytro Malynka
  • April 24, 2025
Snapshots vs. Backups: What’s the Difference?
Snapshots are great for quick rollbacks. Backups are your lifeline in a disaster. Don’t rely on one when you really need the other.
Karim Buzdar
  • Karim Buzdar
  • April 23, 2025
Sudo in Windows: What It Is and How to Use It
No more “Run as Administrator” – Windows 11 (24H2+) now supports sudo, just like Unix /Linux systems! This means you can execute privileged commands with ease, right from the console. Want to know how to set it up?
Brandon Lee
  • Brandon Lee
  • April 22, 2025
Windows Remote Desktop Client End of Support
Microsoft ’s Remote Desktop client is heading for retirement in 2026. If your team relies on it for AVD or Windows 365, now’s the time to start planning.
