Keep your AKS updated with KureD
  • January 12, 2021
  • 3 min read
Cloud and Virtualization Architect. Florent is specializing in public, hybrid, and private cloud technologies. He is a Microsoft MVP in Cloud and Datacenter Management and an MCSE in Private Cloud.
Maybe something that you don’t know, is that Microsoft patches your nodes (every nights), when new patches are available. But, sometime, you need to reboot your nodes, to apply patches. You will find more information here: https://docs.microsoft.com/en-us/azure/aks/node-updates-kured
AKS node update and reboot process with kured
So, to automate the reboot, we will use KureD: https://github.com/kubereboot/kured
KureD is currently only available for Linux nodes.
This DeamonSet will be deployed, as pod, on each nodes of the cluster, and will check if the file /var/run/reboot-required exists. If this file exists, the node will have the status Ready, SchedulingDisabled
To deploy KureD, do the following:
helm repo add kured https://weaveworks.github.io/kured
helm repo update
kubectl create namespace kured
helm install kured kured/kured --namespace kured --set nodeSelector."beta\.kubernetes\.io/os"=linux
wp-image-15520
When KureD will detect the file to reboot the node, the KERNEL-VERSION will be updated:
wp-image-15521
With this KureD feature, you will now have an infrastructure up-to-date and your security team will be happy to hear this 🙂
Found Florent’s article helpful? Looking for a reliable, high-performance, and cost-effective shared storage solution for your production cluster?
