Managing credentials using the Secret Management PowerShell module
  • August 31, 2023
  • 7 min read
IT Production Manager. Nicolas is primarily focused on Microsoft technologies, he is a Microsoft MVP in Cloud and Datacenter Management.
Secret Management is a new way to manage your credentials with PowerShell. Secret Management uses a vault to store the credentials. You can for example store your credentials locally using the SecretStore extension, but what is very interesting is to store credentials remotely using third-party secret vaults such as: Azure Key Vault, KeePass, LastPass, Bitwarden, …
You can see the list here:
PS > Find-Module -Tag "SecretManagement"
Secret Management Module
The great advantage of this module is to handle many scenarios explained by Microsoft:
  • Sharing a script across the organization without knowing the local vault of all the users
  • Running a deployment script in local, test and production with the change of only a single parameter (-Vault)
  • Changing the backend of the authentication method to meet specific security or organizational needs without needing to update all my scripts
In this article, I will describe how to use the Secret Management module with the Azure Key Vault extension.
Getting Started
First, we need to install the Secret Management module using the following command:
PS > Install-Module Microsoft.PowerShell.SecretManagement
Below is the output.
Below is the output
Next, we need to install the Azure Key Vault module using the following command:
PS > Install-Module Az.KeyVault
Now, we need to create a Service Principal to interact with your Azure Key Vault.
Open the Azure portal, go to Azure Active Directory -> App Registrations and create a new one. Then copy/paste the AppID + TenantID + create a secret.
Azure Key Vault
Now, you can use this PowerShell code to interact with your Azure environment.
$appid = ”xxxxxxxxxxxxxxxxxx”
$key = ”yyyyyyyyyyyyyyyy”
$directoryId = ”zzzzzzzzzzzzzzzzzz”
$pass = ConvertTo-SecureString -String $key -AsPlainText -Force
$splat = @{
TypeName = "System.Management.Automation.PSCredential"
ArgumentList = "$appid" , $pass
$cred = New-Object @splat
Login-AzAccount -Credential $cred -ServicePrincipal -TenantId $Directoryid
Then, create a new Azure Key Vault using the portal
Create a new Azure Key Vault using the portal
Go to the Access policies tab, and create a new one.
Access policies tab
Select the permissions you want to apply, in my case I need at least Get and List permissions.
Then, apply the policy to the Service Principal previously created.
Apply the policy to the Service Principal previously created
Everything is OK, we can now register the Azure Key Vault as a new Secret Vault:
PS > Register-SecretVault -Module Az.KeyVault -Name SyncToAzKeyVault -VaultParameters @{
AZKVaultName = "KeyVault-PowerShell"
SubscriptionId = "XXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXX"
PS > Get-SecretVault
Register the Azure Key Vault as a new Secret Vault
Now you can test if you can access to your vault using PowerShell:
PS > Test-SecretVault
The output should be True
wp-image-22022
Everything is configured, you can now create a secret. In the Azure portal, go to your Azure Key Vault, click Secrets and Generate/Import.
In my example, I created a secret named PowerShell.
We can try to retrieve the secret from our Azure Key Vault:
# Get secret as securestring
PS > Get-Secret -Name PowerShell -Vault SyncToAzKeyVault
# Get secret in clear Text
PS > Get-Secret -Name PowerShell -Vault SyncToAzKeyVault -AsPlainText
The first command retrieves the secret as secure string, and the second one retrieves the secret as plain text.
Now, we can delete a secret, but I will need to update the access policy.
Update the access policy
I need to add the delete permission.
wp-image-22026
We can confirm that our secret no long exists.
Une image contenant texte, capture d’écran, Police, Bleu électrique Description générée automatiquement
Nothing appears in the portal.
wp-image-22028
And now, we can create a new secret but we also need to update the access policy.
We can create a new secret but we also need to update the access policy
Then, we can create a new secret named PowerShell2.
PS > $pass = ConvertTo-SecureString -String "Welcome" -AsPlainText -Force
PS > Set-Secret -Name PowerShell2 -Vault SyncToAzKeyVault -SecureStringSecret $pass
PS > Get-Secret -Name PowerShell2 -Vault SyncToAzKeyVault
PS > Get-Secret -Name PowerShell2 -Vault SyncToAzKeyVault -AsPlainText
Below is the output
And we can confirm in the portal that the new secret has been created.
We can confirm in the portal that the new secret has been created
Hey! Found Nicolas’s article helpful? Looking to deploy a new, easy-to-manage, and cost-effective hyperconverged infrastructure?
