No Active Directory for your AVD? Not an issue with Azure AD Join
  • March 24, 2022
  • 6 min read
Cloud and Virtualization Architect. Florent is specializing in public, hybrid, and private cloud technologies. He is a Microsoft MVP in Cloud and Datacenter Management and an MCSE in Private Cloud.
In previous article (How to start with Azure Virtual Desktop) we deployed a host pool using Active Directory.
In a case where you don’t have Active Directory, but only Azure AD, it is possible to do a domain join for an AVD, to this Azure AD. Some known limitations are present: Deploy Azure AD joined VMs in Azure Virtual Desktop – Azure | Microsoft Docs
Let’s start by adding a new host pool, dedicated for this tutorial:
New host pool
We will now add a new virtual machine to this host pool:
Add a new virtual machine to this host pool
Choose the VNet part:
And the most important part, the domain join. Choose Azure AD instead of Active Directory. You can enroll the VM if you need, to manage software, etc. in the VM.
The deployment is finished and VM are Azure AD join:
All devices
Now, edit the RDP properties of your host pool and, in advanced, add targetisaadjoined:i:1
RDP properties
After few minutes, we can now see that the 2 hosts are up:
We can now see that the 2 hosts are up
Now that AVD session hosts are up and running, we need to add more permissions before trying to login. On each session host, you need to add accounts/groups that need to connect to this host pool, as Virtual Machine User Login in Azure RBAC. I will add this right at the resource group level:
I will try to connect to https://rdweb.wvd.microsoft.com/arm/webclient
I have the following error:
Error
I need to assign a session host to this user:
Individual assignments
And after, I can assign this user to a VM:
Session hosts
And create a workspace associated to this Application group:
Application group
I can now see the application:
All resources
If I try to connect, I have the following error:
Following error
Same issue with the fat client:
Windows Security
It is a normal error. I’m using per-assigned MFA. To start, we will create a new conditional policy, based on the following article:
Azure multifactor authentication for Azure Virtual Desktop – Azure | Microsoft Docs
Go to Conditional Access – Microsoft Azure and create a new policy. Assign this policy to a group, a user or all users:
Select an app for which it will be applied, in this case the Azure Virtual Desktop one, with the id 9cdead84-a844-4324-93f2-b2e6bb768d07:
In the Conditions, select to which client app we need to apply this:
Conditions
For the control, select Grant access and check the box Require multi-factor authentication:
Grant access
In session, I will tell that we need to reauthenticate with MFA every 15 days:
We need to reauthenticate with MFA every 15 days
Enable the policy and save it:
Now, go to your users in Azure AD and click on Per-User MFA. On the new tab, disable the MFA for the users that you want to allow the connection to AVD:
MFA
Reconnect to the web interface. You need to login with your account and the MFA. And for the SessionDesktop, it now works:
SessionDesktop
SessionDesktop
As you can see, if you have only cloud based directory (Azure AD), you can use Azure Virtual Desktop, in combination with Intune/Conditional Access, to do not deploy an Active Directory only to join a domain and connect with a domain account.
Hey! Found Florent’s insights useful? Looking for a cost-effective, high-performance, and easy-to-use hyperconverged platform?
Taras Shved
