Recreating VMDK descriptor files for disks and their snapshots in VMware vSphere virtual machines
  • March 28, 2023
  • 14 min read
Virtualization Architect. Alex is a certified VMware vExpert and the Founder of VMC, a company focused on virtualization, and the CEO of Nova Games, a mobile game publisher.
Sometimes, while working with VMware vSphere virtual machines, admins encounter an error with VMDK descriptor files that goes like this:
  • The virtual machine disk file is listed in the Datastore Browser, but does not have an icon
  • When powering on a virtual machine, you see a “File not found” error
  • The  <vm_name>-flat.vmdk file is in the virtual machine’s directory but the <vm_name>.vmdk is not visible
  • The  <vm_name>.vmdk file does not exist or is corrupted
These events can occur due to different reasons, but they always mean one thing: the disk descriptor file for the VM’s disk is either corrupted or missing. You can still fix everything if the <vm_name>-flat.vmdk file still exists and is preserved completely. The whole process of recreating the disk descriptor file for the virtual machine’s disk is quite straightforward, as you can see for yourself from the article or this video below:
Let’s take a look at two separate aspects of this issue, which are recreating the disk descriptor file for the virtual machine’s disk and the disk descriptor files for snapshots.
Part 1 – Recreating a VMDK descriptor file for the VM’s disk
Before proceeding with the steps below, make sure you have a full VM copy (remember that the files could be scattered through different directories, it depends on the VM’s settings). If there’s a backup and you don’t mind recovering it, then it will be simpler and safer to just go with that.
Long story short, to recreate a VDMK descriptor file you need to do the following:
1. Connect to the VMware ESXi host as root through SSH. You can also perform operations through the DCUI console itself.
2. Navigate to the directory that contains the VM to identify and record the exact size of the <vm_name>-flat.vmdk file using this command:
# ls -l <vm_name>-flat.vmdk
You will see the disk size in bytes. The output is supposed to look something like that:
-rw------- 1 root root 4294967296 Oct 11 12:30 vmdisk0-flat.vmdk
3. Recreate the VMDK (<vm_name>.vmdk) file using the disk size from the previous step:
# vmkfstools -c 4294967296 -a lsilogic -d thin temp.vmdk
Now, rename the descriptor file for the new disk to the file we will need for the original disk. Furthermore, delete the empty disk that we will no longer need (temp-flat.vmdk).
4. Open the renamed descriptor file and change the red lines:
# Disk DescriptorFile
version=1
CID=fb183c20
parentCID=ffffffff
createType=”vmfs”
# Extent description
RW 8388608 VMFS “vmdisk0-flat.vmdk”
# The Disk Data Base
#DDB
ddb.virtualHWVersion = “4”
ddb.geometry.cylinders = “522”
ddb.geometry.heads = “255”
ddb.geometry.sectors = “63”
ddb.adapterType = “lsilogic”
ddb.thinProvisioned = “1”
If the original disk was not thin provisioned (thin disk), remove the last red line. Such an option had been added to avoid waiting for the new disk’s initialization (which could take a long time).
There’s also an option to change the adapter type with the ddb.adapterType = lsilogic на ddb.adapterType = pvscsi in case the paravirtualized SCSI controller was used.
To check the disk chain for consistency, run this command:
vmkfstools -e filename.vmdk
If everything is fine, you’ll see output similar to:
Disk chain is consistent.
If there’s a problem, the output will be something like this:
Disk chain is not consistent : The parent virtual disk has been modified since the child was created. The content ID of the parent virtual disk does not match the corresponding parent content ID in the child (18).
If you’re successful, power the VM after adding it back to the vSphere Client environment.
Part 2 – Recreating descriptor files for the VM’s snapshots (delta-files)
The situation is getting more complicated if the VM happens to have snapshots, which makes the virtual machine directory look like this (important files are marked with red color once again):
drwxr-xr-x 1 root root 1400 Aug 16 09:39 .
drwxr-xr-t 1 root root 2520 Aug 16 09:32 ..
-rw——- 1 root root 32768 Aug 17 19:11 examplevm-000002-delta.vmdk
-rw——- 1 root root 32768 Aug 17 19:11 examplevm-000002.vmdk
-rw——- 1 root root 32768 Aug 16 14:39 examplevm-000001-delta.vmdk
-rw——- 1 root root 32768 Aug 16 14:39 examplevm-000001.vmdk
-rw——- 1 root root 16106127360 Aug 16 09:32 examplevm-flat.vmdk
-rw——- 1 root root 469 Aug 16 09:32 examplevm.vmdk
-rw——- 1 root root 18396 Aug 16 14:39 examplevm-Snapshot1.vmsn
-rw——- 1 root root 18396 Aug 17 19:11 examplevm-Snapshot2.vmsn
-rw——- 1 root root 397 Aug 16 09:39 examplevm.vmsn
-rwxr-xr-x 1 root root 1626 Aug 16 09:39 examplevm.vmx
-rw——- 1 root root 259 Aug 16 09:36 examplevm.vmxf
You can find more details about the appropriate procedure there, here we are only covering the basics (let me say to you one more time that you do need to back up all virtual machine files before any operations):
1. Selecting the required files
Basically, virtual machine snapshot files are stored in the vmfsSparse format, paired together with delta extent file, where all the data actually is (such as examplevm-000001-delta.vmdk).
That way, using the aforementioned example, we need to locate snapshot files like examplevm-000001.vmdk and examplevm-000002.vmdk. Keep in mind, though, that both disks and their snapshots could be in different directories on different datastores, which is why the first step is to find out where you keep them. In case you have doubts about the names, check for them in vmware.log to find out the necessary paths.
2. Creating a new snapshot descriptor
Assume that the descriptor file for the delta disk examplevm-000001.vmdk is missing or corrupted. Let’s recreate a descriptor from its associated file examplevm.vmdk by copying it:
# cp examplevm.vmdk examplevm-000001.vmdk
3. Changing the information to data for the snapshot file
Now we need to open this file in text and start modifying it. Looks something like this:
version=1
encoding=”UTF-8″
CID=19741890
parentCID=ffffffff
createType=”vmfs”
RW 31457280 VMFS “examplevm-flat.vmdk”
#DDB
ddb.virtualHWVersion = “7”
ddb.longContentID = “5fd87dda1dc77cafd5be881a19741890”
ddb.uuid = “60 00 C2 9e 3d 8d 45 82-dd 1f e4 93 22 da 9c 61”
ddb.geometry.cylinders = “1958”
The lines marked with red color are those that we are going to change, the lines marked with blue are the ones we are going to delete.
Do the following with this file:
  • The CID=19741890 line is going to be replaced with a randomly generated eight-digits value (disk identifier)
  • The parentCID=ffffffff line is going to be replaced with the parentCID=19741890 line (parent disk identifier; could be a parent snapshot)
  • The createType=”vmfs” line is going to be replaced with the createType=”vmfsSparse” line
  • The RW 31457280 VMFS “examplevm-flat.vmdk” line is going to be replaced with the RW 31457280 VMFSSPARSE “examplevm-000001-delta.vmdk” line (the 31457280 number stays the same – as it is supposed to stay the same for all delta disks)
4. Adding the information inherent to the snapshot file
  • Now we’re going to add something new to the snapshot:
Under the createType=”vmfsSparse” line we are going to add the parentFileNameHint=”examplevm.vmdk” line
Time to remove stuff we don’t need anymore. Delete the following lines from the file (these are only necessary for the original disk):
ddb.virtualHWVersion = "7"
 ddb.uuid = "60 00 C2 9e 3d 8d 45 82-dd 1f e4 93 22 da 9c 61"
 ddb.geometry.cylinders = "1958"
 ddb.geometry.heads = "255"
 ddb.geometry.sectors = "63"
 ddb.adapterType = "lsilogic"
This one can stay though:
ddb.longContentID = "5fd87dda1dc77cafd5be881a19741890"
That way, you’re supposed to see output similar to:
 version=1
 encoding="UTF-8"
 CID=7f3a1e17
 parentCID=19741890
 createType="vmfsSparse"
 parentFileNameHint="examplevm.vmdk"
 RW 31457280 VMFSSPARSE "examplevm-000001-delta.vmdk"
 #DDB
 881a19741890"
After that, try powering the VM with the snapshot. Don’t forget to check the descriptor integration using this command:
This algorithm will work for further levels of delta snapshots if their data disks are alright. Just don’t forget to create backups prior to making any changes and good luck!
Hey! Found Alex’s article helpful? Looking to deploy a new, easy-to-manage, and cost-effective hyperconverged infrastructure?
What’s next?
Product
Virtualization Platform [Hypervisor]
Country
  • Afghanistan (‫افغانستان‬‎)+93
  • Albania (Shqipëri)+355
  • Algeria (‫الجزائر‬‎)+213
  • American Samoa+1
  • Andorra+376
  • Angola+244
  • Anguilla+1
  • Antigua and Barbuda+1
  • Argentina+54
  • Armenia (Հայաստան)+374
  • Aruba+297
  • Ascension Island+247
  • Australia+61
  • Austria (Österreich)+43
  • Azerbaijan (Azərbaycan)+994
  • Bahamas+1
  • Bahrain (‫البحرين‬‎)+973
  • Bangladesh (বাংলাদেশ)+880
  • Barbados+1
  • Belarus (Беларусь)+375
  • Belgium (België)+32
  • Belize+501
  • Benin (Bénin)+229
  • Bermuda+1
  • Bhutan (འབྲུག)+975
  • Bolivia+591
  • Bosnia and Herzegovina (Босна и Херцеговина)+387
  • Botswana+267
  • Brazil (Brasil)+55
  • British Indian Ocean Territory+246
  • British Virgin Islands+1
  • Brunei+673
  • Bulgaria (България)+359
  • Burkina Faso+226
  • Burundi (Uburundi)+257
  • Cambodia (កម្ពុជា)+855
  • Cameroon (Cameroun)+237
  • Canada+1
  • Cape Verde (Kabu Verdi)+238
  • Caribbean Netherlands+599
  • Cayman Islands+1
  • Central African Republic (République centrafricaine)+236
  • Chad (Tchad)+235
  • Chile+56
  • China (中国)+86
  • Christmas Island+61
  • Cocos (Keeling) Islands+61
  • Colombia+57
  • Comoros (‫جزر القمر‬‎)+269
  • Congo (DRC) (Jamhuri ya Kidemokrasia ya Kongo)+243
  • Congo (Republic) (Congo-Brazzaville)+242
  • Cook Islands+682
  • Costa Rica+506
  • Côte d’Ivoire+225
  • Croatia (Hrvatska)+385
  • Cuba+53
  • Curaçao+599
  • Cyprus (Κύπρος)+357
  • Czech Republic (Česká republika)+420
  • Denmark (Danmark)+45
  • Djibouti+253
  • Dominica+1
  • Dominican Republic (República Dominicana)+1
  • Ecuador+593
  • Egypt (‫مصر‬‎)+20
  • El Salvador+503
  • Equatorial Guinea (Guinea Ecuatorial)+240
  • Eritrea+291
  • Estonia (Eesti)+372
  • Eswatini+268
  • Ethiopia+251
  • Falkland Islands (Islas Malvinas)+500
  • Faroe Islands (Føroyar)+298
  • Fiji+679
  • Finland (Suomi)+358
  • France+33
  • French Guiana (Guyane française)+594
  • French Polynesia (Polynésie française)+689
  • Gabon+241
  • Gambia+220
  • Georgia (საქართველო)+995
  • Germany (Deutschland)+49
  • Ghana (Gaana)+233
  • Gibraltar+350
  • Greece (Ελλάδα)+30
  • Greenland (Kalaallit Nunaat)+299
  • Grenada+1
  • Guadeloupe+590
  • Guam+1
  • Guatemala+502
  • Guernsey+44
  • Guinea (Guinée)+224
  • Guinea-Bissau (Guiné Bissau)+245
  • Guyana+592
  • Haiti+509
  • Honduras+504
  • Hong Kong (香港)+852
  • Hungary (Magyarország)+36
  • Iceland (Ísland)+354
  • India (भारत)+91
  • Indonesia+62
  • Iran (‫ایران‬‎)+98
  • Iraq (‫العراق‬‎)+964
  • Ireland+353
  • Isle of Man+44
  • Israel (‫ישראל‬‎)+972
  • Italy (Italia)+39
  • Jamaica+1
  • Japan (日本)+81
  • Jersey+44
  • Jordan (‫الأردن‬‎)+962
  • Kazakhstan (Казахстан)+7
  • Kenya+254
  • Kiribati+686
  • Kosovo+383
  • Kuwait (‫الكويت‬‎)+965
  • Kyrgyzstan (Кыргызстан)+996
  • Laos (ລາວ)+856
  • Latvia (Latvija)+371
  • Lebanon (‫لبنان‬‎)+961
  • Lesotho+266
  • Liberia+231
  • Libya (‫ليبيا‬‎)+218
  • Liechtenstein+423
  • Lithuania (Lietuva)+370
  • Luxembourg+352
  • Macau (澳門)+853
  • Madagascar (Madagasikara)+261
  • Malawi+265
  • Malaysia+60
  • Maldives+960
  • Mali+223
  • Malta+356
  • Marshall Islands+692
  • Martinique+596
  • Mauritania (‫موريتانيا‬‎)+222
  • Mauritius (Moris)+230
  • Mayotte+262
  • Mexico (México)+52
  • Micronesia+691
  • Moldova (Republica Moldova)+373
  • Monaco+377
  • Mongolia (Монгол)+976
  • Montenegro (Crna Gora)+382
  • Montserrat+1
  • Morocco (‫المغرب‬‎)+212
  • Mozambique (Moçambique)+258
  • Myanmar (Burma) (မြန်မာ)+95
  • Namibia (Namibië)+264
  • Nauru+674
  • Nepal (नेपाल)+977
  • Netherlands (Nederland)+31
  • New Caledonia (Nouvelle-Calédonie)+687
  • New Zealand+64
  • Nicaragua+505
  • Niger (Nijar)+227
  • Nigeria+234
  • Niue+683
  • Norfolk Island+672
  • North Korea (조선 민주주의 인민 공화국)+850
  • North Macedonia (Северна Македонија)+389
  • Northern Mariana Islands+1
  • Norway (Norge)+47
  • Oman (‫عُمان‬‎)+968
  • Pakistan (‫پاکستان‬‎)+92
  • Palau+680
  • Palestine (‫فلسطين‬‎)+970
  • Panama (Panamá)+507
  • Papua New Guinea+675
  • Paraguay+595
  • Peru (Perú)+51
  • Philippines+63
  • Poland (Polska)+48
  • Portugal+351
  • Puerto Rico+1
  • Qatar (‫قطر‬‎)+974
  • Réunion (La Réunion)+262
  • Romania (România)+40
  • Russia (Россия)+7
  • Rwanda+250
  • Saint Barthélemy+590
  • Saint Helena+290
  • Saint Kitts and Nevis+1
  • Saint Lucia+1
  • Saint Martin (Saint-Martin (partie française))+590
  • Saint Pierre and Miquelon (Saint-Pierre-et-Miquelon)+508
  • Saint Vincent and the Grenadines+1
  • Samoa+685
  • San Marino+378
  • São Tomé and Príncipe (São Tomé e Príncipe)+239
  • Saudi Arabia (‫المملكة العربية السعودية‬‎)+966
  • Senegal (Sénégal)+221
  • Serbia (Србија)+381
  • Seychelles+248
  • Sierra Leone+232
  • Singapore+65
  • Sint Maarten+1
  • Slovakia (Slovensko)+421
  • Slovenia (Slovenija)+386
  • Solomon Islands+677
  • Somalia (Soomaaliya)+252
  • South Africa+27
  • South Korea (대한민국)+82
  • South Sudan (‫جنوب السودان‬‎)+211
  • Spain (España)+34
  • Sri Lanka (ශ්‍රී ලංකාව)+94
  • Sudan (‫السودان‬‎)+249
  • Suriname+597
  • Svalbard and Jan Mayen+47
  • Sweden (Sverige)+46
  • Switzerland (Schweiz)+41
  • Syria (‫سوريا‬‎)+963
  • Taiwan (台灣)+886
  • Tajikistan+992
  • Tanzania+255
  • Thailand (ไทย)+66
  • Timor-Leste+670
  • Togo+228
  • Tokelau+690
  • Tonga+676
  • Trinidad and Tobago+1
  • Tunisia (‫تونس‬‎)+216
  • Turkey (Türkiye)+90
  • Turkmenistan+993
  • Turks and Caicos Islands+1
  • Tuvalu+688
  • U.S. Virgin Islands+1
  • Uganda+256
  • Ukraine (Україна)+380
  • United Arab Emirates (‫الإمارات العربية المتحدة‬‎)+971
  • United Kingdom+44
  • United States+1
  • Uruguay+598
  • Uzbekistan (Oʻzbekiston)+998
  • Vanuatu+678
  • Vatican City (Città del Vaticano)+39
  • Venezuela+58
  • Vietnam (Việt Nam)+84
  • Wallis and Futuna (Wallis-et-Futuna)+681
  • Western Sahara (‫الصحراء الغربية‬‎)+212
  • Yemen (‫اليمن‬‎)+967
  • Zambia+260
  • Zimbabwe+263
  • Åland Islands+358
