SQL Tools on a pod on AKS to manage your Azure SQL databases
  • July 27, 2021
  • 3 min read
Cloud and Virtualization Architect. Florent is specializing in public, hybrid, and private cloud technologies. He is a Microsoft MVP in Cloud and Datacenter Management and an MCSE in Private Cloud.
If you want to manage/test connectivity to your private SQL server, that are using private endpoint for example, and without deploying a VM, installing SQL Server Management Studio and so on, you can use AKS to do this.
To start, deploy a pod that we will customize later:
kubectl apply -f https://k8s.io/examples/application/shell-demo.yaml
Connect to the pod itself:
kubectl exec -it shell-demo -- /bin/bash
Install sqlcmd tool:
apt-get update && apt-get install gnupg2
curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
curl https://packages.microsoft.com/config/ubuntu/16.04/prod.list | tee /etc/apt/sources.list.d/msprod.list
apt-get update && apt-get install mssql-tools unixodbc-dev
ls /opt/mssql-tools/bin/sqlcmd*
ln -sfn /opt/mssql-tools/bin/sqlcmd /usr/bin/sqlcmd
wp-image-16954
Connect to your database server, with the following sql command, and your credentials:
sqlcmd -S starwind.database.windows.net -U starwind -P 'Demo2021!'
select name from sys.databases
go
wp-image-16955
This is very interesting to manage your databases, or to try a connection from a private AKS cluster to a SQL Server that is using a private endpoint connection for example.
Found Florent’s article helpful? Looking for a reliable, high-performance, and cost-effective shared storage solution for your production cluster?
