Thick and Thin Provisioning: What’s the performance difference in the context of KVM qcow
  • December 24, 2024
  • 11 min read
StarWind Virtual SAN Product Manager. Dmytro is an expert in virtualization and storage systems, specializing in their design, deployment, and optimization.
Exploring Thick and Thin Provisioning in KVM? Discover the pros, cons, and performance impacts to find your perfect option.
What is KVM?
Kernel-based Virtual Machine (KVM) is a virtualization module within the Linux kernel that enables the creation and management of virtual machines (VMs) that run Linux or other operating systems as guests. KVM operates as a Type-1 hypervisor on Linux, utilizing the host’s hardware features, such as CPU virtualization extensions, to provide efficient and high-performance virtualization. It works in conjunction with QEMU (Quick EMUlator) to handle hardware emulation and VM management, allowing KVM to deliver optimized performance for virtualized workloads while maintaining low overhead.
Understanding Thick Provisioning in KVM
How Thick Provisioning Works with KVM
Thick provisioning, also known as fixed or eager provisioning, involves pre-allocating the entire disk space requested for a VM upfront. If a VM requests 100 GB, thick provisioning will allocate the full 100 GB of disk space from the storage pool, regardless of the actual usage. In KVM, this can be set when creating the storage volumes, especially with formats like RAW, which is a straightforward, non-compressed, non-copy-on-write format that takes up the full specified space immediately.
Since the storage is allocated at the outset, thick provisioning reduces the need for on-demand allocation, reducing performance delays caused by disk space expansion or fragmentation. In many scenarios, administrators opt for thick provisioning to secure predictable and high-performance storage for high-demand applications, though it comes at the cost of lower storage efficiency.
 Advantages and Disadvantages of Thick Provisioning
Advantages of Thick Provisioning
  1. Performance Consistency: Pre-allocated storage avoids the delay of growing the disk file during operations, improving I/O performance for the VM. In addition here we can mention reduced fragmentation as well. With dedicated space on the disk, fragmentation is less likely, allowing the VM to access storage without unnecessary delays.
  2. Simplified Management: With fixed space allocations, storage monitoring and management are simpler, minimizing unexpected out-of-space issues for critical VMs.
  1. Low Storage Efficiency: By allocating the entire requested storage in advance, thick provisioning can lead to wasted space if the VM doesn’t fully utilize it.
  2. Limited Scalability: For dynamic workloads, thick provisioning requires pre-planning to avoid storage exhaustion, making it less flexible for environments that experience rapid storage fluctuations.
  3. Higher Initial Cost: Requires more upfront storage capacity, which could mean higher expenses for hardware, especially in storage-constrained environments.
Understanding Thin Provisioning in KVM
Thin provisioning is an allocation method where storage is provided to VMs only as they use it instead of pre-allocating the entire disk space at the start. Thin provisioning in KVM allows the VM to “grow” as more storage is required, which conserves space by preventing the overallocation of unused resources.
How Thin Provisioning Works with KVM
In KVM, thin provisioning typically relies on the QCOW (QEMU Copy-On-Write) format, which is a flexible, feature-rich storage format that allows for dynamic storage allocation. Unlike RAW, which pre-allocates the full disk space immediately, QCOW starts small and expands as data is added, accommodating both snapshots and thin provisioning.
The “copy-on-write” nature means that changes are only written to the disk when new data is added, making it more storage-efficient but potentially slower in high I/O scenarios. This reduces the amount of storage initially consumed and ensures that space is used efficiently. However, this mechanism can introduce a performance penalty in high I/O environments, as it may cause additional overhead when reading and writing data.
What is the QCOW Format?
QCOW is a QEMU disk image format that supports features such as compression, encryption, and snapshots, making it ideal for thin provisioning in virtual environments. When a VM requires additional space, QCOW dynamically allocates it, which means the file can expand up to its maximum size only when necessary. This allows administrators to over-commit resources, giving each VM the storage it needs without consuming large amounts of physical space unnecessarily.
Advantages and Disadvantages of Thin Provisioning
Advantages of Thin Provisioning
  1. Higher Storage Efficiency: Only the used portions of storage are allocated, leading to better space utilization.
  2. Cost Savings: Thin provisioning minimizes unused space, allowing IT teams to reduce upfront storage costs by allocating physical storage only as needed.
  3. Scalability: With dynamically growing storage, thin provisioning allows easy scaling, particularly useful for environments with fluctuating workloads.
  1. Performance Overhead: When additional space is required, the process of expanding the disk can lead to latency, especially in high I/O scenarios.
  2. Risk of Overcommitment: Thin provisioning can lead to issues if the storage pool becomes exhausted and multiple VMs require space simultaneously.
  3. Fragmentation: Thin provisioning can cause fragmentation over time, potentially degrading performance as storage blocks are allocated incrementally.
Head-to-head comparison of performance between thick and thin provisioning
This table below highlights how thick and thin provisioning offer different advantages in KVM environments, with each suited to specific types of applications and storage management strategies.
Thick provisioning  Thin provisioning
Disk Space Allocation Allocates full requested space upfront  Allocates space as data is added, expanding as needed
Performance  Offers consistent and predictable performance  May introduce latency due to on-demand allocation
Storage Efficiency  Lower, as full space is pre-allocated, even if unused  Higher, since only used space is allocated
Fragmentation  Low fragmentation, as space is pre-allocated  Potential for fragmentation due to incremental allocation
Scalability  Limited; must plan for full disk space at setup  Highly scalable; expands automatically with storage needs
Cost Efficiency Higher upfront cost due to full storage allocation  Cost-effective as it maximizes physical storage usage
Choosing between thick and thin provisioning in a KVM environment largely depends on your storage requirements and workload demands. Thick provisioning offers stability and performance consistency, ideal for applications needing dedicated resources. Thin provisioning, especially when paired with QCOW, provides flexibility and space-efficiency, making it suitable for environments where storage efficiency and cost management are priorities.
In high-demand or critical applications, thick provisioning might be the right choice to ensure 100% consistent performance. Conversely, for general workloads, thin provisioning can offer significant storage savings and flexibility without the overhead of unused allocated space.
Hey! Found Dmytro’s article helpful? Looking to deploy a new, easy-to-manage, and cost-effective hyperconverged infrastructure?
