What Is Data Reduction? Deduplication vs Compression
  • July 30, 2024
  • 13 min read
StarWind Technical Support Engineer. Daryna possesses strong technical skills in building virtualized environments. She has great knowledge and experience in storage system architecture, performance tuning, and system recovery procedures.
Today we will focus on data reduction, specifically exploring deduplication and compression. We will explore how deduplication works to eliminate redundant data and its impact on storage systems, then examine data compression techniques.
This exploration will highlight the practical applications of these data reduction technologies and their role in optimizing modern storage infrastructures.
Data reduction in the context of storage systems refers to various strategies and technologies that aim to decrease the volume of data that needs to be stored or transmitted. This process is crucial for reducing overhead costs associated with data storage and improving data management.
The importance of data reduction extends across various applications, from cloud computing to big data analytics, where the sheer volume of information can be overwhelming and costly to maintain. Effective data reduction helps maintain high data quality and accessibility while optimizing storage and processing resources.
To manage data effectively, it’s essential to understand the various types of data reduction and data optimisation techniques available, and how they can be implemented across different storage systems.
  • Deduplication
    This technique involves scanning data for duplicate copies and storing only one instance of the data. Deduplication can be implemented at various levels—file, block, or even bit level—and is particularly effective in environments with high redundancy like backup systems.
  • Compression
    Compression is a data reduction technique that reduces the size of files by using algorithms to encode information more efficiently. This process works by finding and eliminating statistical redundancies in data, reducing the space required to store it.
  • Data Tiering
    This method involves moving data to different types of storage media based on usage and performance requirements. Frequently accessed data can be kept on faster, more expensive storage, while less frequently accessed data is moved to cheaper, slower storage.
  • Thin Provisioning
    Unlike traditional storage provisioning, which allocates a fixed amount of space to a dataset regardless of the actual space needed, thin provisioning allocates storage dynamically based on current needs. This approach avoids over-provisioning and reduces waste.
Benefits of data reduction and data optimization
Efficiently managing data is not just a technical necessity but a strategic asset that can drive cost savings and operational efficiency. Data reduction techniques play a crucial role in optimizing how data is stored, accessed, and managed.
Let’s explore the various benefits of data reduction and its positive impact on business operations and sustainability.
  • Cost Savings
    By reducing the amount of physical storage required, organizations can lower their storage costs. This includes reduced hardware expenses, maintenance, and energy consumption of running storage devices.
  • Improved IT Infrastructure Efficiency
    Data reduction techniques like deduplication, compression, and thin provisioning help streamline data management processes. This results in faster data retrieval and backup times, enhancing overall system performance.
  • Enhanced Data Management
    With less data, it becomes easier to manage, backup, and restore information. Organizations can perform these tasks more quickly and with fewer resources, improving operational efficiency.
  • Extended Storage Lifespan
    Reducing the data load on storage systems frees up space and prolongs the lifespan of existing storage infrastructure by reducing wear and tear and delaying the need for further investments.
  • Better Data Security
    With less data to monitor and control, enforcing security policies can become more manageable. Reduced data also means a smaller attack surface, potentially lowering the risk of data breaches.
Deduplication & Compression – What’s the difference?
What is Deduplication?
Deduplication – is a data-saving technique that identifies and eliminates redundant data across files or datasets. Instead of storing multiple copies of the same data, deduplication retains a single instance and uses reference markers, such as hash numbers or pointers, to refer back to the original data. This method significantly reduces the amount of storage space required.
Deduplication improves storage efficiency by ensuring that only unique data is stored. When data is needed, the system uses the reference markers to retrieve the single stored copy, ensuring quick access without compromising data integrity. This technique is particularly effective for organizations handling large amounts of repetitive data.
Types of Deduplication:
  • Inline Deduplication – Eliminates redundant data before it is written to storage, reducing the initial amount of data stored but adding computational overhead.
  • Post-process Deduplication – Identifies and removes redundant data after it has been written to storage, allowing for immediate data availability but requiring additional processing later.
What is Compression?
Data compression reduces the size of data by eliminating redundant elements and optimizing the encoding of information. This technique makes data more compact without losing essential content, enhancing storage efficiency and speeding up data transmission.
Compression can be viewed as a form of deduplication because lossless compression, in particular, achieves data reduction by eliminating redundancy without losing any original information.
Types of Compression:
  • Lossless Compression – Preserves all original data, allowing for exact reconstruction. This is ideal for applications requiring data integrity, such as text documents and executable files.
  • Lossy Compression – Eliminates some data to achieve higher compression rates, suitable for applications where some loss of quality is acceptable, such as images, videos, and audio files.
Compression Processes:
  • Inline Compression – Reduces data size before it is stored or transmitted, adding computational overhead.
  • Post-process Compression – Compresses data after it has been stored or during transmission, which can add latency but avoids initial computational overhead.
Deduplication vs. Compression
Let’s summarize the key differences between deduplication and compression:
Feature Deduplication Compression
Definition Removes duplicate copies of repeating data. Reduces data size by encoding it more efficiently.
Method Uses pointers to replace duplicate instances. Uses algorithms to eliminate redundant data.
Data Integrity No data loss; original data is preserved. Lossless keeps data intact; lossy may discard some data.
Performance Impact Adds computational overhead and will impact write performance. Adds computational overhead and can impact write performance or transmission performance if performed on-fly.
Best Use Cases Ideal for VDI and backup storage where redundancy is high. Effective for general file storage, media storage, and data transmission.
Implementation Complexity Generally straightforward in targeted environments. Can be slightly more complex depending on the algorithm used and the particular use case.
Size Reduction Rate Varies greatly depending on data redundancy; can be significant in high-redundancy environments. Can range from moderate to high depending on the type of data and compression method used.
How Starwind Delivers on Data Reduction?
StarWind Virtual SAN tackles data reduction challenges by implementing inline deduplication with an industry-standard 4 KB block size for optimal efficiency and deduplication ratios. Following deduplication, optional compression of data blocks further optimizes storage.
This approach allows StarWind VSAN to reduce storage costs while maintaining high performance. When used as a backup repository, StarWind VSAN provides global deduplication, surpassing the limited deduplication capabilities found within individual backup jobs.
By applying deduplication and compression before data reaches the storage array, StarWind Virtual SAN maximizes usable storage space. This process enhances storage utilization efficiency and significantly reduces the overall expenses of operating your storage infrastructure.
Data reduction is a game-changer in modern storage management. Deduplication cuts down on redundant data, and compression shrinks file sizes, making your storage more efficient and cost-effective.
By adopting these strategies, you can save on storage costs, boost your system performance, and enhance data security. These techniques also prolong the life of your storage systems and simplify data management.
As your data continues to grow, leveraging deduplication and compression isn’t just smart — it’s essential. Embrace these technologies to stay ahead, keep things efficient, and make data management a breeze for your organization.
Hey! Found Daryna’s article helpful? Looking to deploy a new, easy-to-manage, and cost-effective hyperconverged infrastructure?
