What’s Inside Broadcom’s Emulex Secure Fibre Channel HBA
  • March 4, 2025
  • 13 min read
Virtualization Architect. Alex is a certified VMware vExpert and the Founder of VMC, a company focused on virtualization, and the CEO of Nova Games, a mobile game publisher.
Broadcom recently introduced Emulex Secure Fibre Channel HBA, which hardware encrypt traffic between servers and storage with minimal impact on performance.
Emulex Secure HBAs are a cost-effective, easy-to-manage solution that encrypts all data in flight (EDIF), protecting it as it moves between databases, applications, servers, and storage.
wp-image-30680
Emulex Secure HBA integrates post-quantum cryptography (PQC) algorithms, ensuring reliable data protection even in the face of threats from quantum computing and AI that threaten traditional encryption methods. And it must be said that these threats are quite real in the next few years – Gartner writes that by 2029, the development of quantum computing will lead to the fact that traditional data protection algorithms will become unreliable.
Secure HBA are the most advanced solutions of 2025, providing a high level of security, performance and manageability for critical infrastructures. In the face of increasing cyber threats, traditional data protection methods, such as the use of NGFW/WAF firewalls, are becoming insufficient, and software encryption creates an additional burden. The combination of artificial intelligence and quantum computing increases the risk of data compromise if it is not encrypted at all stages of processing, including transmission over the storage network.
Safety
Broadcom’s session-based key management solution, designed to the new ANSI/INCITS FC-SP-3 standard, eliminates the need for complex and expensive key management software. Compared to other encryption methods, such as application-level encryption, Emulex Secure HBA can encrypt entire applications at a lower cost and without impacting storage services such as compression, deduplication, and ransomware detection.
wp-image-30681
Emulex Secure HBA adapter provides a cost-effective and easy-to-manage solution that provides end-to-end encryption data in-flight (EDIF) as it moves between databases, applications, servers, and storage systems.
Emulex Secure HBAs integrate post-quantum cryptography (PQC) algorithms to ensure encrypted data remains secure even as quantum computers and AI codebreakers advance and threaten traditional encryption methods.
Simple and efficient key management system
  • Uses session-based key management based on the new ANSI/INCITS FC-SP-3 standard.
  • No need for complex and expensive key management software.
Advantages over other encryption methods
  • Encrypts data for absolutely all applications (as opposed to software encryption at the application level).
  • Provides lower costs without sacrificing performance.
  • Does not affect key storage system functions such as:
    • Data compression
    • Deduplication
    • Ransomware detection
In the context of modern data security requirements, including regulations such as CNSA 2.0, DORA and NIS 2, Emulex Secure HBA offers a reliable and efficient security solution that complies with the principles of Zero Trust and provides quantum-resistant security.
Performance
With hardware acceleration of cryptographic functions, Emulex Secure HBAs provide encryption without reducing overall system performance. The adapters support high throughput and low latency, which is especially important for modern applications that require fast data access. They support both NVMe over FC and SCSI FC simultaneously, providing flexibility and compatibility with various enterprise storage systems.
The Emulex Dynamic Multi-core architecture provides high performance and maximum port utilization with 8 fully redundant compute cores and 16 threads that dynamically distribute ASIC resources between ports depending on their load, ensuring service level agreements (SLAs) are met.
Compared to Gen 6 HBAs, Gen 7 Emulex HBAs support 64GFC, providing up to 2x greater throughput.
wp-image-30682
Emulex Gen 7 HBA Performance:
  • Delivers 12,800 MB/s (two 32GFC ports) or 25,600 MB/s (two 64GFC ports) in full duplex mode.
  • Delivers 3x lower hardware latency than previous generations.
  • 64GFC LPe38100-series adapters deliver over 10 million IOPS (!), one of the best in the industry.
Model Variations and Backward Compatibility:
  • LPe38100-series are available in single or dual 64GFC fiber interface configurations, and are backward compatible with 32GFC and 16GFC networks.
  • The LPe37100-series is available in single or dual 32GFC optics configurations, and is backward compatible with 16GFC and 8GFC networks.
  • The LPe37100-series is upgradeable to 64GFC using Broadcom-qualified optics.
Here is the LPe38102 64GFC adapter benchmark result with hardware encryption enabled versus database-level software encryption performance, as reported by StorageReview:
wp-image-30683
Manageability and Deployment with Emulex SAN Manager
Emulex Secure HBAs integrate easily into your existing FC SAN infrastructure without the need to upgrade it. To simplify network management and monitoring, the optional Emulex SAN Manager software provides:
  • Visualization of network congestions with a dashboard that displays throughput and congestion graphs.
  • Automatic congestion avoidance with the adaptive management feature.
  • Comprehensive visibility into HBAs on the network, including hostnames, operating system versions, software, and firmware.
  • Transceiver health monitoring to detect optics degradation.
  • A multipath configuration validation tool to identify configuration errors.
  • Network-wide visibility into encryption capabilities and policies, as well as detailed information about encrypted connections and post-quantum cryptography usage at the port level.
wp-image-30684
Emulex SAN Manager is the industry’s first solution that automatically identifies, minimizes, and resolves application performance issues caused by SAN congestion using FPIN-CN technology.
Operational Efficiency
Emulex Gen 7 HBAs deliver improved reliability, availability, and serviceability (RAS), including port isolation and port-level fault isolation, allowing users to quickly identify, isolate, and resolve faults.
Intelligent SAN Management
Emulex HBAs fully support industry standards, complementing Broadcom Autonomous SAN technology. These technologies enable the storage network to self-learn, self-optimize, and self-heal, ensuring maximum SAN performance and preventing downtime.
wp-image-30685
Support for new Fabric Performance Impact Notifications (FPINs) standards:
  • FPIN-LI (Link Integrity Notification) – notification of connection integrity.
  • FPIN-CN (Congestion Notification) – notification of network congestion.
  • FPIN-PN (Peer Congestion Notification) – notification of congestion from adjacent devices.
  • FPIN-DN (Delivery Notification) – notification of data delivery problems.
Ease of management and reduced operational costs
  • Firmware updates without rebooting the server – changes in queue depth or replacement of optics are performed without system downtime.
  • Hot-Plug of optical modules – optics can be replaced without turning off the server, ensuring continuous operation.
  • Centralized management of HBA adapters – the Emulex HBA Manager application supports management of both current and previous generations of Emulex FC HBA.
Diagnostics and Troubleshooting
The Emulex HBA Capture tool collects system, adapter, and driver information into a single compressed file that can be sent to Broadcom Technical Support for diagnostics and troubleshooting.
wp-image-30686
Deep Integration with Brocade Fabric Vision
Emulex HBAs support all key Brocade Fabric Vision features, enabling seamless integration of servers with SAN switches.
wp-image-30687
Supported functions:
  • ClearLink (D_Port) – diagnostics of optical connection quality.
  • Link Cable Beaconing – indication of active cables.
  • Host Name Registration – automatic host name registration.
  • Read Diagnostic Parameters – analysis of diagnostic parameters.
  • Support for VMID tags to ensure visibility of virtual machine traffic.
  • BB Credit Recovery – technology for preventing problems associated with frame loss.
  • FC Trace Route and FC Ping – diagnostics of network connections.
  • REST API – automation of SAN network management.
In the context of modern cyber threats and increasing demands for data security, Emulex Secure Fibre Channel HBA from Broadcom is an advanced solution that provides reliable protection of information during its transfer between servers and storage systems. The integration of post-quantum cryptography algorithms and support for the ANSI/INCITS FC-SP-3 standard ensure the safety of data even in the era of quantum computing and artificial intelligence. With hardware acceleration of cryptographic functions, these adapters provide high performance without compromising storage-related services such as compression and deduplication. Ease of management via Emulex SAN Manager and compliance with modern security standards make Emulex Secure HBA the optimal choice for mission-critical infrastructures that require maximum protection and efficiency.
Hey! Found Alex’s insights useful? Looking for a cost-effective, high-performance, and easy-to-use hyperconverged platform?
Taras Shved
What’s next?
Product
Virtualization Platform [Hypervisor]
Country
  • Afghanistan (‫افغانستان‬‎)+93
  • Albania (Shqipëri)+355
  • Algeria (‫الجزائر‬‎)+213
  • American Samoa+1
  • Andorra+376
  • Angola+244
  • Anguilla+1
  • Antigua and Barbuda+1
  • Argentina+54
  • Armenia (Հայաստան)+374
  • Aruba+297
  • Ascension Island+247
  • Australia+61
  • Austria (Österreich)+43
  • Azerbaijan (Azərbaycan)+994
  • Bahamas+1
  • Bahrain (‫البحرين‬‎)+973
  • Bangladesh (বাংলাদেশ)+880
  • Barbados+1
  • Belarus (Беларусь)+375
  • Belgium (België)+32
  • Belize+501
  • Benin (Bénin)+229
  • Bermuda+1
  • Bhutan (འབྲུག)+975
  • Bolivia+591
  • Bosnia and Herzegovina (Босна и Херцеговина)+387
  • Botswana+267
  • Brazil (Brasil)+55
  • British Indian Ocean Territory+246
  • British Virgin Islands+1
  • Brunei+673
  • Bulgaria (България)+359
  • Burkina Faso+226
  • Burundi (Uburundi)+257
  • Cambodia (កម្ពុជា)+855
  • Cameroon (Cameroun)+237
  • Canada+1
  • Cape Verde (Kabu Verdi)+238
  • Caribbean Netherlands+599
  • Cayman Islands+1
  • Central African Republic (République centrafricaine)+236
  • Chad (Tchad)+235
  • Chile+56
  • China (中国)+86
  • Christmas Island+61
  • Cocos (Keeling) Islands+61
  • Colombia+57
  • Comoros (‫جزر القمر‬‎)+269
  • Congo (DRC) (Jamhuri ya Kidemokrasia ya Kongo)+243
  • Congo (Republic) (Congo-Brazzaville)+242
  • Cook Islands+682
  • Costa Rica+506
  • Côte d’Ivoire+225
  • Croatia (Hrvatska)+385
  • Cuba+53
  • Curaçao+599
  • Cyprus (Κύπρος)+357
  • Czech Republic (Česká republika)+420
  • Denmark (Danmark)+45
  • Djibouti+253
  • Dominica+1
  • Dominican Republic (República Dominicana)+1
  • Ecuador+593
  • Egypt (‫مصر‬‎)+20
  • El Salvador+503
  • Equatorial Guinea (Guinea Ecuatorial)+240
  • Eritrea+291
  • Estonia (Eesti)+372
  • Eswatini+268
  • Ethiopia+251
  • Falkland Islands (Islas Malvinas)+500
  • Faroe Islands (Føroyar)+298
  • Fiji+679
  • Finland (Suomi)+358
  • France+33
  • French Guiana (Guyane française)+594
  • French Polynesia (Polynésie française)+689
  • Gabon+241
  • Gambia+220
  • Georgia (საქართველო)+995
  • Germany (Deutschland)+49
  • Ghana (Gaana)+233
  • Gibraltar+350
  • Greece (Ελλάδα)+30
  • Greenland (Kalaallit Nunaat)+299
  • Grenada+1
  • Guadeloupe+590
  • Guam+1
  • Guatemala+502
  • Guernsey+44
  • Guinea (Guinée)+224
  • Guinea-Bissau (Guiné Bissau)+245
  • Guyana+592
  • Haiti+509
  • Honduras+504
  • Hong Kong (香港)+852
  • Hungary (Magyarország)+36
  • Iceland (Ísland)+354
  • India (भारत)+91
  • Indonesia+62
  • Iran (‫ایران‬‎)+98
  • Iraq (‫العراق‬‎)+964
  • Ireland+353
  • Isle of Man+44
  • Israel (‫ישראל‬‎)+972
  • Italy (Italia)+39
  • Jamaica+1
  • Japan (日本)+81
  • Jersey+44
  • Jordan (‫الأردن‬‎)+962
  • Kazakhstan (Казахстан)+7
  • Kenya+254
  • Kiribati+686
  • Kosovo+383
  • Kuwait (‫الكويت‬‎)+965
  • Kyrgyzstan (Кыргызстан)+996
  • Laos (ລາວ)+856
  • Latvia (Latvija)+371
  • Lebanon (‫لبنان‬‎)+961
  • Lesotho+266
  • Liberia+231
  • Libya (‫ليبيا‬‎)+218
  • Liechtenstein+423
  • Lithuania (Lietuva)+370
  • Luxembourg+352
  • Macau (澳門)+853
  • Madagascar (Madagasikara)+261
  • Malawi+265
  • Malaysia+60
  • Maldives+960
  • Mali+223
  • Malta+356
  • Marshall Islands+692
  • Martinique+596
  • Mauritania (‫موريتانيا‬‎)+222
  • Mauritius (Moris)+230
  • Mayotte+262
  • Mexico (México)+52
  • Micronesia+691
  • Moldova (Republica Moldova)+373
  • Monaco+377
  • Mongolia (Монгол)+976
  • Montenegro (Crna Gora)+382
  • Montserrat+1
  • Morocco (‫المغرب‬‎)+212
  • Mozambique (Moçambique)+258
  • Myanmar (Burma) (မြန်မာ)+95
  • Namibia (Namibië)+264
  • Nauru+674
  • Nepal (नेपाल)+977
  • Netherlands (Nederland)+31
  • New Caledonia (Nouvelle-Calédonie)+687
  • New Zealand+64
  • Nicaragua+505
  • Niger (Nijar)+227
  • Nigeria+234
  • Niue+683
  • Norfolk Island+672
  • North Korea (조선 민주주의 인민 공화국)+850
  • North Macedonia (Северна Македонија)+389
  • Northern Mariana Islands+1
  • Norway (Norge)+47
  • Oman (‫عُمان‬‎)+968
  • Pakistan (‫پاکستان‬‎)+92
  • Palau+680
  • Palestine (‫فلسطين‬‎)+970
  • Panama (Panamá)+507
  • Papua New Guinea+675
  • Paraguay+595
  • Peru (Perú)+51
  • Philippines+63
  • Poland (Polska)+48
  • Portugal+351
  • Puerto Rico+1
  • Qatar (‫قطر‬‎)+974
  • Réunion (La Réunion)+262
  • Romania (România)+40
  • Russia (Россия)+7
  • Rwanda+250
  • Saint Barthélemy+590
  • Saint Helena+290
  • Saint Kitts and Nevis+1
  • Saint Lucia+1
  • Saint Martin (Saint-Martin (partie française))+590
  • Saint Pierre and Miquelon (Saint-Pierre-et-Miquelon)+508
  • Saint Vincent and the Grenadines+1
  • Samoa+685
  • San Marino+378
  • São Tomé and Príncipe (São Tomé e Príncipe)+239
  • Saudi Arabia (‫المملكة العربية السعودية‬‎)+966
  • Senegal (Sénégal)+221
  • Serbia (Србија)+381
  • Seychelles+248
  • Sierra Leone+232
  • Singapore+65
  • Sint Maarten+1
  • Slovakia (Slovensko)+421
  • Slovenia (Slovenija)+386
  • Solomon Islands+677
  • Somalia (Soomaaliya)+252
  • South Africa+27
  • South Korea (대한민국)+82
  • South Sudan (‫جنوب السودان‬‎)+211
  • Spain (España)+34
  • Sri Lanka (ශ්‍රී ලංකාව)+94
  • Sudan (‫السودان‬‎)+249
  • Suriname+597
  • Svalbard and Jan Mayen+47
  • Sweden (Sverige)+46
  • Switzerland (Schweiz)+41
  • Syria (‫سوريا‬‎)+963
  • Taiwan (台灣)+886
  • Tajikistan+992
  • Tanzania+255
  • Thailand (ไทย)+66
  • Timor-Leste+670
  • Togo+228
  • Tokelau+690
  • Tonga+676
  • Trinidad and Tobago+1
  • Tunisia (‫تونس‬‎)+216
  • Turkey (Türkiye)+90
  • Turkmenistan+993
  • Turks and Caicos Islands+1
  • Tuvalu+688
  • U.S. Virgin Islands+1
  • Uganda+256
  • Ukraine (Україна)+380
  • United Arab Emirates (‫الإمارات العربية المتحدة‬‎)+971
  • United Kingdom+44
  • United States+1
  • Uruguay+598
  • Uzbekistan (Oʻzbekiston)+998
  • Vanuatu+678
  • Vatican City (Città del Vaticano)+39
  • Venezuela+58
  • Vietnam (Việt Nam)+84
  • Wallis and Futuna (Wallis-et-Futuna)+681
  • Western Sahara (‫الصحراء الغربية‬‎)+212
  • Yemen (‫اليمن‬‎)+967
  • Zambia+260
  • Zimbabwe+263
  • Åland Islands+358
