The new infrastructure powered by StarWind vSAN meets all
of our performance and fault tolerance needs.
System Administrator
PROBLEM
Before StarWind Virtual SAN (vSAN) deployment, Graham Corporation had expensive physical Nimble SAN which was a single point of failure (SPOF) and took a lot of rack space. The company needed a virtual shared storage solution to achieve fault tolerance and reduce IT operational expenses.
SOLUTION
Using StarWind vSAN, Graham Corporation deployed a high availability storage cluster. Since StarWind vSAN is customizable, there was no need to change the existing IT infrastructure. Thanks to StarWind, the company saved money and reduced its rack space usage by one-third. In the future, Graham Corporation plans to use StarWind for its VDI project.
About the Company
Graham Corporation is a New York-based designer and manufacturer of vacuum and heat transfer equipment for energy markets and process industries worldwide.
Company Profile
Oil and Gas
Contact Person
