With StarWind HCA, everything works like a dream and when I do have issues,
support is there for me. StarWind software and systems are great and all,
but the Support and the knowledge they possess are way above par.
Director IT
PROBLEM
Before implementing StarWind HCI Appliance (HCA), Kelly Aerospace had a small older PC-based server farm with no redundancy or reliable backup solutions. It was built and added on through the years with no real growth plan. So, the company needed to replace its existing servers with a plan for future growth and redundancy. Kelly Aerospace did look briefly at several providers, but after viewing some demos and taking advice from someone that was using StarWind at the time, they ultimately chose StarWind and could not be happier.
SOLUTION
Kelly Aerospace has chosen StarWind HCA as it seemed a very practical, easy-to-manage, and out-of-the-box turnkey solution. To accomplish the same thing without StarWind would have been a very large task involving many different technologies and external specialists to set up. Being a very small IT department, this was not feasible and would have cost exponentially more in the long run. StarWind HCA gave the company the newer technologies that the old PC-based servers could never offer them. Also, the critical issue of redundancy was fixed. As the business does grow, Kelly Aerospace feels confident that StarWind can help them meet needs and new requirements going forward.
StarWind HyperConverged Appliance Configuration | |
Appliance Model | HCA P-Spec 13.4 |
Cluster Size | 2 nodes |
Cluster density | 2U |
Servers | Dell PowerEdge R640 |
CPU | 2 х Intel Silver 4208, 2.1 GHz, 8 cores, 16 threads per node |
Memory | 8 x 16GB Dell DDR4 Registered (128 GB total) per node |
Cluster Storage Capacity | 13.4 TB of SSD storage |
Disk Configuration | Dell Perc H740P MiniMono Controller 8 x Dell 1.92TB 6Gbps SATA Mix Use TLC 2.5″ SSD S4610 per node Dell BOSS 2 x 240GB M.2 SSD |
Networking | Mellanox ConnectX-4 Lx Dual Port 25GbE DA/SFP |
Hypervisor | Hyper-V on Windows Server 2019 |
About the Company
Kelly Aero is a leading original equipment manufacturing supplier to the aviation industry and the world’s largest private OEM for aircraft aftermarket magnetos, replacement parts, and ignition harness based in Montgomery, U.S.
Company Profile
Aviation Manufacturing/Repair
Contact Person
Director IT
