StarWind Virtual HCI Appliance: Configuration Guide for Oracle Linux Virtualization Manager [KVM], VHCA Deployed using Automated Installation
- June 04, 2024
- 25 min read
- Download as PDF
Annotation
Relevant products
StarWind Virtual HCI Appliance (VHCA)
Purpose
This document outlines how to configure a StarWind Virtual HCI Appliance (VHCA) based on Red Hat oVirt, with VSAN running as a Controller Virtual Machine (CVM). The guide includes steps to prepare oVirt hosts for clustering, configure physical and virtual networking, and set up the Virtual SAN Controller Virtual Machine.
Audience
This technical guide is intended for storage and virtualization architects, system administrators, and partners designing virtualized environments using StarWind Virtual HCI Appliance (VHCA).
Expected result
The end result of following this guide will be a fully configured high-availability StarWind Virtual HCI Appliance (VHCA) powered by Red Hat oVirt that includes virtual machine shared storage provided by StarWind VSAN.
Prerequisites
StarWind Virtual HCI Appliance (VHCA) system requirements
Prior to configuring StarWind Virtual HCI Appliance (VHCA), please make sure that the system meets the requirements, which are available via the following link:
Solution diagram
Prerequisites:
1. 2 servers with local storage, which have direct network connections for Synchronization and iSCSI/StarWind heartbeat traffic.
2. Servers should have local storage available for OS installation and StarWind VSAN Controller Virtual Machine. CVM utilizes local storage to create replicated shared storage connected to oVirt nodes via iSCSI.
3. DNS records of the Oracle Linux Nodes and OLVM Engine should be added to DNS Server. It is required to use static IP addresses for the Oracle Linux nodes and the OLVM Engine.
4. StarWind HA devices require at least 2 separate network links between the nodes. The first one is used for iSCSI traffic, the second one is used for Synchronization traffic.
Note. The network interfaces on each node for Synchronization and iSCSI/StarWind heartbeat interfaces should be in different subnets and connected directly according to the network diagram above. Here, the 172.16.10.x subnet is used for the iSCSI/StarWind heartbeat traffic, while the 172.16.20.x subnet is used for the Synchronization traffic.
Deploying Oracle Linux node
1. Download Oracle Linux 8 iso.
https://yum.oracle.com/ISOS/OracleLinux/OL8/u10/x86_64/OracleLinux-R8-U10-x86_64-dvd.iso
2. Boot from the downloaded ISO.
3. Choose “Installation Destination” and choose drive, which will be used for OS installation. Choose “Custom” storage configuration.
4. Click “Done” and partition your drive. At least 70 GiB should be left assigned for the “/” partition. It will be used for StarWind VSAN Controller VM deployment.
5. Install Oracle Linux on your host.
Preconfiguring Oracle Linux hosts
1. Connect to the node via SSH or to a local console.
2. Download vHCI archive with StarWind CVM and configuration files to the Oracle Linux node.
1 |
curl -k -O https://tmplink.starwind.com/StarWind_vHCI_KVM_scripts.zip |
3. Unzip the archive.
1 2 |
mkdir StarWind_vHCI_KVM_scripts unzip StarWind_vHCI_KVM_scripts.zip -d StarWind_vHCI_KVM_scripts |
3. Run node_predeploy.sh script.
1 2 3 |
cd ./StarWind_vHCI_KVM_scripts/ chmod +x node_predeploy.sh ./node_predeploy.sh |
4. Type node number (01 or 02). Press Enter.
5. Type the name of the Management interface. Press Enter.
6. Type the name of the Data interface. Press Enter.
7. Type the name of the Replication interface. Press Enter.
8. If DHCP server is available on the network, IP of the StarWind CVM will be displayed in the script out put.
Note. If DHCP is not available, static IP address should be configured.
9. Repeat steps 1-8 on every node.
Configuring StarWind VSAN Controller VM
1. Login to node via SSH.
2. Check VM display using the following command.
1 |
virsh -c qemu:///system?authfile=/etc/ovirt-hosted-engine/virsh_auth.conf domdisplay CVM01 |
NOTE. Depending on the output you should connect to the VM display via Spice or VNC console.
3. Create tunnel to the host using the following command using SSH client.
1 |
ssh -L 5906:127.0.0.1:5906 root@%hostipaddress% |
4. Connect to VM using Virt-Viewer and login using the following credentials.
• Username: user
• Password: rds123RDS
Note. Virt-Manager can be downloaded here:
https://virt-manager.org/download.html
5. Open the file corresponding to the Management interface using a text editor, for example: sudo nano /etc/sysconfig/network-scripts/ifcfg-eth0
6. Edit the file:
Change the line BOOTPROTO=dhcp to: BOOTPROTO=static
Add the IP settings needed to the file:
IPADDR=192.168.12.10
NETMASK=255.255.255.0
GATEWAY=192.168.12.1
DNS1=192.168.1.1
7. Now, open the web browser and enter the IP address of the VM. Log into the VM using the following default credentials:
• Username: user
NOTE: Make sure to check the “Reuse my password for privileged tasks” box.
8. After a successful login, click Accounts on the left sidebar.
9. Select a user and click Set Password.
10. On the left sidebar, click Networking.
Here, the Management IP address of the StarWind Virtual SAN Virtual Machine can be configured, as well as IP addresses for iSCSI and Synchronization networks. In case the Network interface is inactive, click on the interface, turn it on, and set it to Connect automatically.
11. Configure IP addresses for each interface.
12. The result should look like in the picture below:
NOTE: It is recommended to set MTU to 9000 on interfaces dedicated for iSCSI and Synchronization traffic. Change Automatic to 9000, if required.
13. Access the Storage section. Locate the recently added disk in the Drives section and choose it.
14. The added disk does not have any partitions and filesystem. Press the Create Partition Table button to create the partition.
15. Press Create Partition to format the disk and set the mount point. The mount point should be as follows: /mnt/%yourdiskname%
16. On the Storage section, under Content, navigate to the Filesystem tab. Click Mount.
17. Repeat steps 1-16 on every node.
1. Install StarWind Management Console on each server or on a separate workstation with Windows OS (Windows 7 or higher, Windows Server 2008 R2 and higher) using the installer available here.
2. Select the appropriate option to apply the StarWind License key.
3. Open StarWind Management Console and click Add Server.
6. Click Apply Key… on the pop-up window.
7. Select Load license from file and click the Load button.
NOTE: In order to manage StarWind Virtual SAN service (e.g. create ImageFile devices, VTL devices, etc.), StarWind Management Console can be used.
Creating StarWind devices
Note. oVirt hosted engine requires shared storage to be deployed. Create StarWind HA device for hosted engine at this stage. HA devices for VMs should be created after hosted engine deployment.
1. In the StarWind Management Console click to Add Device (advanced) button and open Add Device (advanced) Wizard.
2. Select Hard Disk Device as the type of device to be created.
3. Select Virtual Disk.
4. Specify a virtual disk Name, Location, and Size.
5. Select the Thick provisioned disk type and block size.
NOTE: Use 4096 sector size for targets, connected on Windows-based systems and 512 bytes sector size for targets, connected on Linux-based systems (ESXi/Xen/KVM).
6. Define a caching policy and specify a cache size (in MB). Also, the maximum available cache size can be specified by selecting the appropriate checkbox. Optionally, define the L2 caching policy and cache size.
7. Specify Target Parameters. Select the Target Name checkbox to enter a custom target name. Otherwise, the name is generated automatically in accordance with the specified target alias.
8. Click Create to add a new device and attach it to the target.
9. Click Close to finish the device creation.
Synchronous or active-active replication ensures real-time synchronization and load balancing of data between two or three cluster nodes. Such a configuration tolerates the failure of two out of three storage nodes and enables the creation of an effective business continuity plan. With synchronous mirroring, each write operation requires control confirmation from both storage nodes. It guarantees the reliability of data transfers but is demanding in bandwidth since mirroring will not work on high-latency networks.
1. Right-click the recently created device and select Replication Manager from the shortcut menu.
2. Select the Add Replica button in the top menu.
3. Select Synchronous “Two-Way” replication as a replication mode.
4. Specify a partner Host name or IP address and Port Number.
Heartbeat
Node Majority
The Node Majority failover strategy ensures the synchronization connection without any additional heartbeat links. The failure-handling process occurs when the node has detected the absence of the connection with the partner.
Heartbeat
1. Select Failover Strategy.
2. Select Create new Partner Device and click Next.
3. Select a partner device Location and click Next.
4. Select Synchronization Journal Strategy and click Next.
5. Click Change Network Settings.
6. Specify the interfaces for Synchronization and Heartbeat Channels. Click OK and then click Next.
7. In Select Partner Device Initialization Mode, select Synchronize from existing Device and click Next.
8. Click Create Replica. Click Finish to close the wizard.
The successfully added device appears in StarWind Management Console.
9. Follow the same procedure for the creation of other virtual disks that will be used as storage repositories.
Node Majority
There are two ways to configure Witness for 2-nodes StarWind HA device, created with Node Majority Failover Strategy: File Share (SMB) as Witness and additional server as Witness Node.
– Creating HA device with File SHare(SMB) as Witness:
SMB Witness is a file, located on SMB share, which can be accessed by both nodes and help them to eliminate the split-brain issue in case of synchronization connection interruption between the nodes. To set up the SMB file share as a Witness for 2-nodes HA device with Node Majority Failover Strategy, perform the actions, described on this page:
https://www.starwindsoftware.com/help/ConfiguringFileShareSMBasWitness.html
– Creating HA device with Witness Node:
1. Select the Node Majority failover strategy and click Next.
2. Choose Create new Partner Device and click Next.
3. Specify the partner device Location and modify the target name if necessary. Click Next. Select Synchronization Journal strategy and location and click Next.
4. In Network Options for Replication, press the Change network settings button and select the synchronization channel for the HA device.
5. In Specify Interfaces for Synchronization Channels, select the checkboxes with the appropriate networks and click OK. Then click Next.
6. Select Synchronize from existing Device as the partner device initialization mode.
7. Press the Create Replica button and close the wizard.
8. The added devices will appear in StarWind Management Console.
Adding Witness Node
NOTE: Since the device created in this guide is replicated between 2 active nodes with the Node Majority failover strategy, a Witness node must be added to it.
1. Open StarWind Management Console, right-click on the Servers field and press the Add Server button. Add a new StarWind Server which will be used as the Witness node and click OK.
2. Right-click on the HA device with the configured Node Majority failover policy and select Replication Manager and press the Add Replica button.
3. Select Witness Node.
4. Specify the Witness node Host Name or IP address. The default Port Number is 3261.
5. In Partner Device Setup, specify the Witness device Location. Optionally, modify the target name by clicking the appropriate button.
6. In Network Options for Replication, select the synchronization channel with the Witness node by clicking the Change Network Settings button.
7. Specify the interface for Synchronization and Heartbeat and click OK.
8. Click Create Replica and then close the wizard.
9. Repeat the steps above to create other virtual disks if necessary.
Deploying self-hosted engine
1. Login to Oracle Linux Node, which will be used for self-hosted engine deployment, via SSH. Enable repository for the engine and install it.
1 2 3 |
dnf config-manager --enable ol8_baseos_latest dnf install oracle-ovirt-release-45-el8 dnf install ovirt-engine |
Note. Hosted engine will be deployed as a VM on a shared shared storage of the node chosen for the deployment. Second node should be added separately to OLVM Engine.
2. Remove management network from virsh.
1 2 |
virsh -c qemu:///system?authfile=/etc/ovirt-hosted-engine/virsh_auth.conf net-destroy bridged-mgmt virsh -c qemu:///system?authfile=/etc/ovirt-hosted-engine/virsh_auth.conf net-undefine bridged-mgmt |
3. Login to Oracle Linux node via web. Go to Networking page and choose management bridge. Click Delete.
Note. Management Network in virsh and Management Bridge must be removed before hosted engine deployment. Repeat steps 2-3 on all nodes.
4. Run the following command to install OLVM Engine.
1 2 |
dnf -y install ovirt-engine-appliance --nogpgcheck hosted-engine --deploy --4 |
5. Follow the installation wizard and deploy Self-Hosted engine on iSCSI storage, which was created.
Note. DNS records of the Oracle Linux Nodes and OLVM Engine should be added before engine deployment. It is required to use static IP addresses for the Oracle Linux node and OLVM Engine.
It is recommended to choose default settings during the deployment. IP address and iSCSI drive should be chosen.
6. Login to oVirt Engine after successful installation deployment using the following credentials:
user: admin@ovirt
Password: Configured during OLVM engine deployment.
7. After deployment connect to all paths of iSCSI LUN on every node.
1 2 3 4 |
iscsiadm -m discovery -t st -p 172.16.10.10 iscsiadm -m node -l -T iqn.2008-08.com.starwindsoftware:cvm01-lun01 iscsiadm -m discovery -t st -p 172.16.10.20 iscsiadm -m node -l -T iqn.2008-08.com.starwindsoftware:cvm02-lun01 |
Adding hosts to OLVM Engine
1. Login to OLVM Engine and go to Compute -> Hosts.
2. Type Name, Hostname or IP, Password of the host, which will be added. Click OK.
3. Repeat steps 1-2 for all hosts, which were not added to oVirt engine.
Defining Management Network for StarWind CVM
1. Login to the node via SSH
2. Attach Network interface to StarWind VM.
1 |
virsh -c qemu:///system?authfile=/etc/ovirt-hosted-engine/virsh_auth.conf attach-interface --domain cvm01 --type bridge --source vdsm-ovirtmgmt --target ovirtmgmt --model virtio --config –live |
3. Repeat steps 1-2 on all nodes.
Provisioning StarWind HA Storage to Hosts
1. Login to Engine and open Storage -> Domain. Click New Domain.
2. Choose Storage Type – iSCSI, Host and Name of Storage Domain. Discover targets via iSCSI links, which were previously configured. Click Login All.
3. Add LUN from each iSCSI target. Click OK.
4. Storage Domain will be added to the list of Domain and can be used as a storage for VMs.
5. Login to each host and verify that multipathing policy has been applied using the following command.
1 |
multipath -ll |
Following this guide, a StarWind Virtual HCI Appliance (VHCA) powered by Oracle Linux Virtualization Manager was deployed and configured with StarWind Virtual SAN (VSAN) running in a CVM on each host. As a result, a virtual shared storage “pool” accessible by all cluster nodes was created for storing highly available virtual machines.
