IMPORTANT NOTE: ESXi6.0 is no longer supported by VMware (see more details here: https://lifecycle.vmware.com/). This guide should be used for informational, test, and educational purposes only.
Introduction to StarWind Virtual SAN for Hyper-V
StarWind Virtual SAN is a native Windows hypervisor-centric hardware-less VM storage solution. It creates a fully fault-tolerant and high performing storage pool built for the virtualization workloads by mirroring the existing server’s storage and RAM between the participating storage cluster nodes. The mirrored storage resources are then connected to all cluster nodes and treated just as a local storage by all hypervisors and clustered applications. High Availability (HA) is achieved by providing multipath access to all storage nodes. StarWind Virtual SAN delivers supreme performance compared to any dedicated SAN solution since it runs locally on the hypervisor and all I/O is processed by local RAM, SSD cache, and disks. This way it never gets bottlenecked by storage fabric.
Solution Diagram
The diagram below illustrates the network and storage configuration of the resulting solution described in the guide.
Preparing Hypervisor
Creating Datacenter
NOTE: Before creating Datacenter, the vCenter server should be deployed.
1. Connect to vCenter, select the Getting Started tab.
2. Click on Create Datacenter and enter Datacenter name.
Creating Cluster
1. Click the Datacenter Getting Started tab and click Create a cluster. Enter cluster Name and click OK.
2. Open the Cluster pane and click Add host.
3. Enter the ESXi Host name or IP address and enter the administrative account.
4. Turn on vSphere HA by clicking Manage -> Settings -> vSphere HA-> Edit.
5. In the Cluster Settings window, select the Turn on vSphere HA checkbox.
Configuring Networks
NOTE: Configure network interfaces on each node to make sure that the iSCSI interface is in a different subnet and connected physically according to the network diagram above. In this document, two links with 172.16.30.x and 172.16.40.x subnets per ESXi host are used for iSCSI traffic. All actions below should be taken for each ESXi server.
1. Create vSwitch for the iSCSI traffic via the first Ethernet Switch.
2. Create vSwitch for the iSCSI traffic via the second Ethernet Switch.
NOTE: iSCSI vSwitch requires creating Virtual Machine Port Group and VMKernel. VMKernel port requires assigning static IP address. It is recommended to set jumbo frames to 9000 on vSwitches and VMKernel ports for iSCSI traffic. Additionally, users can enable vMotion on VMKernel port.
3. Create VMKernel ports for iSCSI channels.
4. In VMkernel adapters pane, click Add host networking and Add Virtual Machine Port Group on the vSwitches for iSCSI traffic.
5. In Ready to complete, click Finish.
Preparing StarWind Servers
1. Install Windows Server (see supported OS on system requirements page: https://www.starwindsoftware.com/system-requirements) and StarWind VSAN on each host.
2. Make sure that server hardware used for StarWind Virtual SAN deployment satisfies the requirements listed below.
Minimum requirements:
RAM: 4 GB (plus the size of the RAM cache if applicable);
CPUs: 1 socket with 2 GHz;
Hard disk 1: 100 GB for OS (recommended);
Hard disk 2: Depends on the storage volume to be used as shared storage.
Network adapter 1: Management
Network adapter 2: iSCSI1
Network adapter 3: iSCSI2
Network adapter 4: Sync1
Network adapter 5: Sync2
NOTE: It is recommended to set jumbo frames to 9000 for iSCSI and Synchronization traffic. StarWind host allows adding Active Directory Domain Services role if necessary, thus it can serve as a domain controller.
Installing StarWind VSAN for Hyper-V
1. Download the StarWind setup executable file from the StarWind website:
https://www.starwind.com/registration-starwind-virtual-san
2. Launch the downloaded setup file on the server to install StarWind Virtual SAN or one of its components. The Setup wizard will appear. Read and accept the License Agreement.
3. Carefully read the information about the new features and improvements. Red text indicates warnings for users that are updating the existing software installations.
4. Select Browse to modify the installation path if necessary. Click on Next to continue.
5. Select the following components for the minimum setup:
- StarWind Virtual SAN Service. The StarWind Virtual SAN service is the “core” of the software. It can create iSCSI targets as well as share virtual and physical devices. The service can be managed from StarWind Management Console on any Windows computer that is on the same network. Alternatively, the service can be managed from StarWind Web Console deployed separately.
- StarWind Management Console. Management Console is the Graphic User Interface (GUI) part of the software that controls and monitors all storage-related operations (e.g., allows users to create targets and devices on StarWind Virtual SAN servers connected to the network).
NOTE: To manage StarWind Virtual SAN installed on a Windows Server Core edition with no GUI, StarWind Management Console should be installed on a different computer running the GUI-enabled Windows edition.
6. Specify Start Menu Folder.
7. Enable the checkbox if a desktop icon needs to be created. Click on Next to continue.
8. When the license key prompt appears, choose the appropriate option:
- request time-limited fully functional evaluation key.
- request FREE version key.
- relect the previously purchased commercial license key.
9. Click on the Browse button to locate the license file.
10. Review the licensing information.
11. Verify the installation settings. Click on Back to make any changes or Install to proceed with installation.
12. Enable the appropriate checkbox to launch StarWind Management Console right after the setup wizard is closed and click on Finish.
13. Repeat the installation steps on the partner node.
Provisioning Storage with StarWind VSAN
Creating StarWind HA devices
1. Open StarWind Management Console and click on the Add Device (advanced) button.
2. Select Hard disk device as the type of device to be created. Click Next to continue.
3. Select Virtual disk. Click Next to continue.
4. Specify virtual disk Name, Location, and Size.
NOTE: Image file device and HA device can be extended later according to the steps in KB article:
How to extend Image File or High Availability device
5. Specify virtual disk options.
NOTE: Sector size should be 512 bytes in case of using ESXi.
6. Define the RAM caching policy and specify the cache size (in the corresponding units) and click Next to continue.
7. Define the Flash caching policy and the cache size. Click Next to continue.
8. Specify Target Parameters and select the Allow multiple concurrent iSCSI connections checkbox to enable several clients to connect simultaneously to the target.
9. Click Create to add a new device and attach it to the target.
10. Click Create to add a new device and attach it to the target.
11. Click Finish to close the wizard.
12. Right-click on the recently created device and select Replication Manager from the shortcut menu.
13. Click Add replica.
14. Select Synchronous “Two-Way” Replication as a replication mode.
15. Specify Partner Hostname or IP Address and Port Number. Click Next.
16. Choose Create new Partner Device and click Next.
17. Choose the device Location and specify the target name if required. Otherwise, the name is generated automatically in accordance with the specified target alias.
18. Select Synchronization Journal Strategy and click Next.
19. Click Change Network Settings.
20. Specify the interfaces for Synchronization and Heartbeat channels. Click OK. Then click Next.
21. Choose Synchronize from existing Device
22. Click Create Replica.
23. The successfully added devices appear in the StarWind Management Console.
24. Follow the similar procedure to create other virtual disks that will be used as datastores.
Synchronous or active-active replication ensures real-time synchronization and load balancing of data between two or three cluster nodes. Such a configuration tolerates the failure of two out of three storage nodes and enables the creation of an effective business continuity plan. With synchronous mirroring, each write operation requires control confirmation from both storage nodes. It guarantees the reliability of data transfers but is demanding in bandwidth since mirroring will not work on high-latency networks.
1. Right-click the recently created device and select Replication Manager from the shortcut menu.
2. Select the Add Replica button in the top menu.
3. Select Synchronous “Two-Way” replication as a replication mode.
4. Specify a partner Host name or IP address and Port Number.
Heartbeat
Node Majority
The Node Majority failover strategy ensures the synchronization connection without any additional heartbeat links. The failure-handling process occurs when the node has detected the absence of the connection with the partner.
Heartbeat
1. Select Failover Strategy.
2. Select Create new Partner Device and click Next.
3. Select a partner device Location.
4. Select Synchronization Journal Strategy and click Next.
Disk-based journal placed on a separate disk from StarWind devices. It allows to avoid full synchronization for the devices where it’s configured even when StarWind service is being stopped on all nodes. Disk-based synchronization journal should be placed on a separate, preferably faster disk from StarWind devices. SSDs and NVMe disks are recommended as the device performance is defined by the disk speed, where the journal is located. For example, it can be placed on the OS boot volume.
It is required to allocate 2 MB of disk space for the synchronization journal per 1 TB of HA device size with a disk-based journal configured with 2-way replication and 4MB per 1 TB of HA device size for 3-way replication.
Failure journal
The strategy provides good I/O performance, as a RAM-based journal, while all device nodes are in a healthy synchronized state. If a device on one node went into a not synchronized state, the disk-based journal activates and a performance drop could occur as the device performance is defined by the disk speed, where the journal is located. Fast synchronization is not guaranteed in all cases. For example, if a simultaneous hard reset of all nodes occurs, full synchronization will occur.
Continuous journal
The strategy guarantees fast synchronization and data consistency in all cases. Although, this strategy has the worst I/O performance, because of frequent write operations to the journal, located on the disk, where the journal is located.
5. Click Change Network Settings.
6. Specify the interfaces for Synchronization and Heartbeat Channels. Click OK and then click Next.
7. In Select Partner Device Initialization Mode, select Synchronize from existing Device and click Next.
8. Click Create Replica. Click Finish to close the wizard.
The successfully added device appears in StarWind Management Console.
9. Follow the similar procedure for the creation of other virtual disks that will be used as storage repositories.
Node Majority
There are two ways to configure Witness for 2-nodes StarWind HA device, created with Node Majority Failover Strategy: File Share (SMB) as Witness and additional server as Witness Node.
– Creating HA device with File SHare(SMB) as Witness:
SMB Witness is a file, located on SMB share, which can be accessed by both nodes and help them to eliminate the split-brain issue in case of synchronization connection interruption between the nodes. To set up the SMB file share as a Witness for 2-nodes HA device with Node Majority Failover Strategy, perform the actions, described on this page:
https://www.starwindsoftware.com/help/ConfiguringFileShareSMBasWitness.html
– Creating HA device with Witness Node:
1. Select the Node Majority failover strategy and click Next.
2. Choose Create new Partner Device and click Next.
3. Specify the partner device Location and modify the target name if necessary. Click Next. Select Synchronization Journal strategy and location and click Next.
4. In Network Options for Replication, press the Change network settings button and select the synchronization channel for the HA device.
5. In Specify Interfaces for Synchronization Channels, select the checkboxes with the appropriate networks and click OK. Then click Next.
6. Select Synchronize from existing Device as the partner device initialization mode.
7. Press the Create Replica button and close the wizard.
8. The added devices will appear in StarWind Management Console.
Adding Witness Node
NOTE: Since the device created in this guide is replicated between 2 active nodes with the Node Majority failover strategy, a Witness node must be added to it.
1. Open StarWind Management Console, right-click on the Servers field and press the Add Server button. Add a new StarWind Server which will be used as the Witness node and click OK.
2. Right-click on the HA device with the configured Node Majority failover policy and select Replication Manager and press the Add Replica button.
3. Select Witness Node.
4. Specify the Witness node Host Name or IP address. The default Port Number is 3261.
5. In Partner Device Setup, specify the Witness device Location. Optionally, modify the target name by clicking the appropriate button.
6. In Network Options for Replication, select the synchronization channel with the Witness node by clicking the Change Network Settings button.
7. Specify the interface for Synchronization and Heartbeat and click OK.
8. Click Create Replica and then close the wizard.
9. Repeat the steps above to create other virtual disks if necessary.
https://knowledgebase.starwindsoftware.com/maintenance/how-to-extend-image-file-or-high-availability-device/
Preparing Datastores
Adding Discover Portals
1. To connect the previously created devices to the ESXi host, click on the Storage -> Adapters -> Configure iSCSI and choose the Enabled option to enable Software iSCSI storage adapter.
2. Click Add and select Add Software iSCSI adapter. Click OK.
3. The list of available storage adapters appears. Select iSCSI Software Adapter and open the Targets tab.
4. In the Configure iSCSI window, under Dynamic Targets, click on the Add Dynamic Target button to specify iSCSI interfaces. Add dynamic targets of both storage hosts.
5. Perform the same procedure for each StarWind server by clicking Add and specifying the server IP address.
6. Select Scan for new Storage Devices and Scan for new VMFS Volumes. Then click OK.
7. Repeat the steps 1-6 on the other ESXi node, specifying corresponding IP addresses for the iSCSI subnet.
Creating Datastores
1. Right-click on the host, select New Datastore and choose VMFS.
2. Specify Datastore name and select the device to add to the datastore.
3. Enter Datastore Size and click Next.
4. In Ready to complete, verify the settings and click Finish.
5. Check another host for a new datastore.
6. If the list of existing datastores does not include new datastore, click Rescan Storage...
7. Add another Datastore in the same way and select the second device for the second datastore.
8. Verify that the storages are connected to both hosts. Otherwise, rescan the storage adapter.
9. Path selection policy for datastores changes from Most Recently Used to Round Robin automatically. To check it, click the Configure button, choose the Storage Devices tab, select the device, and click the Edit Multipathing button.
10. Then Select Round Robin MPIO policy.
Additional Tweaks
1. Click the Manage -> Settings->Security Profile->Services->SSH->Edit.
2. Select Start and stop with host in the Startup Policy drop-down list.
3. Connect to the host using SSH client (e.g. Putty).
4. Check the device list using the following commands:
esxcli storage nmp device list
For devices, adjust Round Robin size from 1000 to 1 using the following command:
esxcli storage nmp psp roundrobin deviceconfig set --type=iops --iops=1 --device=
NOTE. Paste StarWind device UID in the end of the command. Also, Rescan Script already contains this parameter and the system performs this action automatically.
5. Repeat the steps 1-4 on each host for each datastore.
