StarWind Virtual SAN: Configuration Guide for Microsoft Azure Stack HCI [Hyper-V], VSAN Deployed as a Controller VM using PowerShell CLI
Annotation
Relevant products
This guide applies to StarWind Virtual SAN and StarWind Virtual SAN Free (Version V8 (Build 15260, OVF Version 20230901) and earlier).
For newer versions of StarWind Virtual SAN (Version V8 (Build 15260, CVM Version 20231016) and later), please refer to this configuration guide: StarWind Virtual SAN: Configuration Guide for Microsoft Azure Stack HCI [Hyper-V], VSAN Deployed as a Controller Virtual Machine using PowerShell CLI
Purpose
This guide is to assist users in the deployment and configuration of StarWind VSAN CVM on Microsoft Azure Stack HCI platforms, emphasizing best practices and system requirements.
Audience
This document is designed for IT professionals, system administrators, and technical users who are looking to deploy and configure StarWind VSAN CVM on Microsoft Azure Stack HCI platforms using PowerShell CLI.
Expected Results
Following this guide, users will get a fully configured Failover Cluster on Microsoft Azure Stack HCI with shared storage provided by StarWind VSAN.
Introduction to StarWind Virtual SAN CVM
StarWind Virtual SAN Controller Virtual Machine (CVM) comes as a prepackaged Linux Virtual Machine (VM) to be deployed on any industry-standard hypervisor. It creates a VM-centric and high-performing storage pool for a VM cluster.
This guide describes the deployment and configuration process of the StarWind Virtual SAN CVM.
StarWind VSAN System Requirements
Pre-configuring the Windows Server Hosts
1. Make sure that a domain controller is configured and the servers are added to the domain.
NOTE: Please follow the recommendation in KB article on how to place a DC in case of StarWind Virtual SAN usage.
2. Deploy Windows Server on each server and install Failover Clustering and Multipath I/O features, as well as the Hyper-V role on both servers. This can be done through Server Manager (Add Roles and Features menu item).
3. Define at least 2x network interfaces on each node that will be used for the Synchronization and iSCSI/StarWind heartbeat traffic. Do not use iSCSI/Heartbeat and Synchronization channels over the same physical link. Synchronization and iSCSI/Heartbeat links can be connected either via redundant switches or directly between the nodes (see diagram above).
4. Separate external  Virtual Switches should be created for iSCSI and Synchronization traffic based on the selected before iSCSI and Synchronization interfaces. Using Hyper-V Manager open Virtual Switch Manager and create two external Virtual Switches: one for the iSCSI/StarWind Heartbeat channel (iSCSI) and another one for the Synchronization channel (Sync).
5. Configure and set the IP address on each virtual switch interface. In this document, the 172.16.10.x subnet is used for iSCSI/StarWind heartbeat traffic, while 172.16.20.x subnet is used for the Synchronization traffic.
NOTE: In case NIC supports SR-IOV, enable it for the best performance. An additional internal switch is required for iSCSI Connection. Contact support for additional details.
6. Set MTU size to 9000 on iSCSI and Sync interfaces using the following Powershell script.
It will apply MTU 9000 to all iSCSI and Sync interfaces if they have iSCSI or Sync as part of their name.
NOTE: MTU setting should be applied on the adapters only if there is no live production running through the NICs.
Enabling Multipath Support
7. Open the MPIO Properties manager: Start -> Windows Administrative Tools -> MPIO. Alternatively, run the following PowerShell command :
8. In the Discover Multi-Paths tab, select the Add support for iSCSI devices checkbox and click Add.
wp-image-13680
9. When prompted to restart the server, click Yes to proceed.
10. Repeat the same procedure on the other server.
Installing File Server Roles
Please follow the steps below if file shares configuration is required
Scale-Out File Server (SOFS) for application data
1. Open Server Manager: Start -> Server Manager.
2. Select: Manage -> Add Roles and Features.
3. Follow the installation wizard steps to install the roles selected in the screenshot below:
StarWind - Select Server Role
4. Restart the server after installation is completed and perform steps above on the each server.
File Server for general use with SMB share
4. Restart the server after installation is completed and perform steps above on each server.
File Server for general use with NFS share
StarWind Select Role NFS
Deploying StarWind Virtual SAN CVM
1. Download StarWind VSAN CVM to the Hyper-V server:
VSAN by StarWind: Overview
2. Extract the VM .vhdx file from the downloaded archive.
3. Open Hyper-V Manager and create a new Hyper-V VM.
4. Specify the name of the virtual machine with StarWind VSAN, and choose the location for the VM. For example: C:\SW1\
5. Copy .vhdx to the folder where the VM was created. In this case, its C:\ SW1\Virtual Hard Disks\
6. Choose Generation 2 VM.
7. Assign memory to the VM. We recommend allocating at least 8GB of RAM for StarWind CVM. If StarWind L1 cache is used, an appropriate amount of RAM should be assigned.
8. Choose the management network for the VM.
9. Connect .vhdx to the VM.
10. Review the Summary and click Finish to create the VM.
11. Right-click on the VM and choose Settings. Open Firmware and move the option Hard Drive to the first place in the list.
12. Go to the Security page and uncheck the Enable Secure Boot box.
13. Go to Memory and move the slider for Memory weight to High.
14. Go to Processor and assign 8 vCPUs to the VM.
15. Click Add Hardware and add NICs for iSCSI and Synchronization traffic to the VM.
VM adding NIC
16. Configure Automatic Start and Stop actions, so the VM will always start automatically.
17. Choose Shut down the guest operating system as an Automatic Stop Action.
18. Repeat all the steps from this section on other Windows Server hosts.
19. Start virtual machines on all Windows Server hosts.
1. Open the VM console and check the IP address received via DHCP (or which was assigned manually).
VM console
Another alternative is to log into the VM via console and assign static IP using nmcli if there is no DHCP,
2. Now, open the web browser and enter the IP address of the VM. Log into the VM using the following default credentials:
  • username: user
  • password: rds123RDS
  • NOTE: Make sure to check the “Reuse my password for privileged tasks” box
VM web login
3. After a successful login, click Accounts on the left sidebar.
4. Select a user and click Set Password.
VM password
5. On the left sidebar, click Networking.
VM networks
Here, the Management IP address of the StarWind Virtual SAN Virtual Machine can be configured, as well as IP addresses for iSCSI and Synchronization networks. In case the Network interface is inactive, click on the interface, turn it on, and set it to Connect automatically.
6. Click on Automatic (DHCP) to set the IP address (DNS and gateway – for Management).
VM IP static
7. The result should look like in the picture below:
VM networks
NOTE: It is recommended to set MTU to 9000 on interfaces dedicated for iSCSI and Synchronization traffic. Change Automatic to 9000, if required.
VM netwroks ISCSI
8. Alternatively, log into the VM via the VMware console and assign a static IP address by editing the configuration file of the interface located by the following path: /etc/sysconfig/network-scripts
9.Open the file corresponding to the Management interface using a text editor, for example: sudo nano /etc/sysconfig/network-scripts/ifcfg-eth0
10. Edit the file:
  • change the line BOOTPROTO=dhcp to: BOOTPROTO=static
  • add the IP settings needed to the file:
  • IPADDR=192.168.12.10
  • NETMASK=255.255.255.0
  • GATEWAY=192.168.12.1
  • DNS1=192.168.1.1
11. Restart the interface using the following cmdlet: sudo ifdown eth0, sudo ifup eth0, or restart the VM.
12. Change the Host Name from the System tab by clicking on it:
VM name
13. Change System time and NTP settings if required:
VM NTP
14. Repeat the steps above on each StarWind VSAN VM.
Configuring Storage
Configuring storage with hardware RAID
1. Open VM Settings in Hyper-V and add drive to the VM, which going to be used by StarWind service. It is recommended to pass the entire RAID array to the VM by selecting a physical hard disk option.
NOTE: Using virtual hard disks is not recommended due to potential performance issues. Thick provisioned virtual disks should be used to improve storage performance.
VM Mount Hard drive
2. Login to StarWind VSAN VM web console and access the Storage section. Locate the recently added disk in the Drives section and choose it.
VM Storage
3.
The added disk does not have any partitions and filesystem. Press the Create Partition Table button to create the partition.
VM Creating partition
4. Press Create Partition to format the disk and set the mount point. The mount point should be as follows: /mnt/%yourdiskname%
VM Formatting
5.
On the Storage section, under Content, navigate to the Filesystem tab. Click Mount.
1. Install StarWind Management Console on each server or on a separate workstation with Windows OS (Windows 7 or higher, Windows Server 2008 R2 and higher) using the installer available here.
2. Select the appropriate option to apply the StarWind License key.
3. Open StarWind Management Console and click Add Server.
Add Server
Add new StarWind server
6. Click Apply Key… on the pop-up window.
Apply key
7. Select Load license from file and click the Load button.
NOTE: In order to manage StarWind Virtual SAN service (e.g. create ImageFile devices, VTL devices, etc.), StarWind Management Console can be used.
Creating StarWind HA LUNs using PowerShell
1. Open PowerShell ISE as Administrator.
2.  Open StarWindX sample CreateHA_2.ps1 using PowerShell ISE. It can be found here:
2.  Configure script parameters according to the following example:
Detailed explanation of script parameters:
-addr, -addr2 — partner nodes IP address.
Format: string. Default value: 192.168.0.1, 192.168.0.1
allowed values: localhost, IP-address
-port, -port2 — local and partner node port.
Format: string. Default value: 3261
-user, -user2 — local and partner node user name.
Format: string. Default value: root
-password, -password2 — local and partner node user password.
Format: string. Default value: starwind
#common
-initMethod
Format: string. Default value: Clear
-size – set size for HA-devcie (MB)
Format: integer. Default value: 12
-sectorSize – set sector size for HA-device
Format: integer. Default value: 512
allowed values: 512, 4096
-failover – set type failover strategy
Format: integer. Default value: 0 (Heartbeat)
allowed values: 0, 1 (Node Majority)
-bmpType – set bitmap type, is set for both partners at once
Format: integer. Default value: 1 (RAM)
allowed values: 1, 2 (DISK)
-bmpStrategy – set journal strategy, is set for both partners at once
allowed values: 0, 1 – Best Performance (Failure), 2 – Fast Recovery (Continuous)
#primary node
-imagePath – set path to store the device file
Format: string. Default value: My computer\C\starwind”. For Linux the following format should be used: “VSA Storage\mnt\mount_point”
-imageName – set name device
Format: string. Default value: masterImg21
-createImage – set create image file
Format: boolean. Default value: true
-targetAlias – set alias for target
Format: string. Default value: targetha21
-poolName – set storage pool
Format: string. Default value: pool1
-aluaOptimized – set Alua Optimized
-cacheMode – set type L1 cache (optional parameter)
Format: string. Default value: wb
allowed values: none, wb, wt
-cacheSize – set size for L1 cache in MB (optional parameter)
Format: integer. Default value: 128
allowed values: 1 and more
-syncInterface – set sync channel IP-address from partner node
Format: string. Default value: “#p2={0}:3260”
-hbInterface – set heartbeat channel IP-address from partner node
Format: string. Default value: “”
-createTarget – set creating target
Format: string. Default value: true
Even if you do not specify the parameter -createTarget, the target will be created automatically.
If the parameter is set as -createTarget $false, then an attempt will be made to create the device with existing targets, the names of which are specified in the -targetAlias (targets must already be created)
-bmpFolderPath – set path to save bitmap file
Format: string.
#secondary node
-imagePath2 – set path to store the device file
Format: string. Default value: “My computer\C\starwind”. For Linux the following format should be used: “VSA Storage\mnt\mount_point”
-imageName2 – set name device
-createImage2 – set create image file
-targetAlias2 – set alias for targetFormat: string.
Default value: targetha22
-poolName2 – set storage pool
-aluaOptimized2 – set Alua Optimized
-cacheMode2 – set type L1 cache (optional parameter)
allowed values: wb, wt
-cacheSize2 – set size for L1 cache in MB (optional parameter)
-syncInterface2 – set sync channel IP-address from partner node
Format: string. Default value: “#p1={0}:3260”
-hbInterface2 – set heartbeat channel IP-address from partner node
-createTarget2 – set creating target
Even if you do not specify the parameter -createTarget, the target will be created automatically.If the parameter is set as -createTarget $false, then an attempt will be made to create the device with existing targets, the names of which are specified in the -targetAlias (targets must already be created)
-bmpFolderPath2 – set path to save bitmap file
Format: string.
Heartbeat
Node Majority
The Node Majority failover strategy ensures the synchronization connection without any additional heartbeat links. The failure-handling process occurs when the node has detected the absence of the connection with the partner.
Provisioning StarWind HA Storage to Windows Server Hosts
1. Launch Microsoft iSCSI InitiatorStart -> Windows Administrative Tools -> iSCSI Initiator. Alternatively, launch it using the command below in the command line interface:
2. Navigate to the Discovery tab.
iscsi
3. Click the Discover Portal button. The Discover Target Portal dialog appears. Type 172.16.10.10.
Discover Portal
4. Click the Advanced button. Select Microsoft iSCSI Initiator as a Local adapter and select Initiator IP. Confirm the actions to complete the Target Portal discovery.
Advanced Settings
5. Click the Discover Portal… button once again.
6. In Discover Target Portal dialog, type in the iSCSI interface IP address of the partner node that will be used to connect the StarWind provisioned targets. Click Advanced.
discover target portal partner
7. Select Microsoft iSCSI Initiator as the Local adapter, select the Initiator IP in the same subnet as the IP address of the partner server from the previous step. Confirm the actions to complete the Target Portal discovery.
Advanced Settings
8. Now, all the target portals are added on the first node.
iSCSI Initiator Properties
9. Repeat the steps 1-8 on the partner node.
Connecting Targets
1. Click the Targets tab. The previously created targets are listed in the Discovered Targets section.
NOTE: If the created targets are not listed, check the firewall settings of the StarWind Server as well as the list of networks served by the StarWind Server (go to StarWind Management Console -> Configuration -> Network). Alternatively, check the Access Rights tab on the corresponding StarWind VSAN server in StarWind Management Console for any restrictions.
initiator properties 3
2. Select the Witness target from the local server and click Connect.
3. Enable checkboxes as shown in the image below. Click Advanced.
Connect To Target
4. Select Microsoft iSCSI Initiator in the Local adapter dropdown menu. In the Initiator IP field, select the IP address for the iSCSI channel. In the Target portal IP, select the corresponding portal IP from the same subnet. Confirm the actions.
iSCSI device connection
5. Repeat the steps 2-4 to connect to partner node.
6. Select the CSV1 target discovered from the local server and click Connect.
7. Enable checkboxes as shown in the image below. Click Advanced.
connect to target multipath
8. Select Microsoft iSCSI Initiator in the Local adapter dropdown menu. In Target portal IP, select 172.16.10.10. Confirm the actions.
9. Select the partner target from the other StarWind node and click Connect.
10. Repeat the step 6.
11. Select Microsoft iSCSI Initiator in the Local adapter dropdown menu. In the Initiator IP field, select the IP address for the iSCSI channel. In the Target portal IP, select the corresponding portal IP from the same subnet. Confirm the actions.
iSCSI device connection 2
11. Repeat the steps 1-10 for all remaining HA device targets.
12. Repeat the steps 1-11 on the other StarWind node, specifying corresponding data channel IP addresses.
Configuring Multipath
NOTE: It is recommended to configure the different MPIO policies depending on iSCSI channel throughput. For 1 Gbps iSCSI channel throughput, it is recommended to set Failover Only or Least Queue Depth MPIO load balancing policy. For 10 Gbps iSCSI channel throughput, it is recommended to set Round Robin or Least Queue Depth MPIO load balancing policy.
1. Configure the MPIO policy for each target with the load balance policy of choice. Select the Target located on the local server and click Devices.
2. In the Devices dialog, click MPIO.
devices
3. Select the appropriate load balancing policy.
4. Repeat the steps 1-3 for configuring the MPIO policy for each remaining device on the current node and on the partner node.
Connecting Disks to Servers
1. Open the Disk Management snap-in. The StarWind disks will appear as unallocated and offline.
disk management
2. Bring the disks online by right-clicking on them and selecting the Online menu option.
3. Select the CSV disk (check the disk size to be sure) and right-click on it to initialize.
4. By default, the system will offer to initialize all non-initialized disks. Use the Select Disks area to choose the disks. Select GPT (GUID Partition Style) for the partition style to be applied to the disks. Press OK to confirm.
initialize disk
5. Right-click on the selected disk and choose New Simple Volume.
6. In New Simple Volume Wizard, indicate the volume size. Click Next.
7. Assign a drive letter to the disk. Click Next.
assign drive letter
8. Select NTFS in the File System dropdown menu. Keep Allocation unit size as Default. Set the Volume Label of choice. Click Next.
NTFS volume
9. Press Finish to complete.
10. Complete the steps 1-9 for the Witness disk. Do not assign any drive letter or drive path for it.
do not assign drive letter
11. On the partner node, open the Disk Management snap-in. All StarWind disks will appear offline. If the status is different from the one shown below, click Action->Refresh in the top menu to update the information about the disks.
12. Repeat step 2 to bring all the remaining StarWind disks online.
Creating a Failover Cluster in Windows Server
NOTE: To avoid issues during the cluster validation configuration, it is recommended to install the latest Microsoft updates on each node.
NOTE: Server Manager can be opened on the server with desktop experience enabled (necessary features should be installed). Alternatively, the Failover cluster can be managed with  Remote Server Administration Tools:
https://docs.microsoft.com/en-us/windows-server/remote/remote-server-administration-tools
NOTE: For converged deployment (SAN & NAS running as a dedicated storage cluster) the Microsoft Failover Cluster is deployed on separate computing nodes. Additionally, for the converged deployment scenario, the storage nodes that host StarWind SAN & NAS as CVM or bare metal do not require a domain controller and Failover Cluster to operate.
1. Open Server Manager. Select the Failover Cluster Manager item from the Tools menu.
failover manager
2. Click the Create Cluster link in the Actions section of Failover Cluster Manager.
failover cluster ws 2016
3. Specify the servers to be added to the cluster. Click Next to continue.
select servers
4. Validate the configuration by running the cluster validation tests: select Yes… and click Next to continue.
validation warning
5. Specify the cluster name.
NOTE: If the cluster servers get IP addresses over DHCP, the cluster also gets its IP address over DHCP. If the IP addresses are set statically, set the cluster IP address manually.
cluster ip
6. Make sure that all settings are correct. Click Previous to make any changes or Next to proceed.
confirmation
NOTE: If checkbox Add all eligible storage to the cluster is selected, the wizard will add all disks to the cluster automatically. The device with the smallest storage volume will be assigned as a Witness. It is recommended to uncheck this option before clicking Next and add cluster disks and the Witness drive manually.
7. The process of the cluster creation starts. Upon the completion, the system displays the summary with the detailed information. Click Finish to close the wizard.
summary
Adding Storage to the Cluster
1. In Failover Cluster Manager, navigate to Cluster -> Storage -> Disks. Click Add Disk in the Actions panel, choose StarWind disks from the list and confirm the selection.
add disks
2. To configure the cluster witness disk, right-click on Cluster and proceed to More Actions -> Configure Cluster Quorum Settings.
configure cluster quorum
3. Follow the wizard and use the Select the quorum witness option. Click Next.
select quorum
4. Select Configure a disk witness. Click Next.
select disk witness
5. Select the Witness disk to be assigned as the cluster witness disk. Click Next and press Finish to complete the operation.
configure storage witness
6. In Failover Cluster Manager, Right-click the disk and select Add to Cluster Shared Volumes.
add csv
7. If renaming of the cluster shared volume is required, right-click on the disk and select Properties. Type the new name for the disk and click Apply followed by OK.
CSV properties
8. Perform the steps 6-7 for any other disk in Failover Cluster Manager. The resulting list of disks will look similar to the screenshot below.
Failover Cluster disks
Configuring Cluster Network Preferences
1. In the Networks section of the Failover Cluster Manager, right-click on the network from the list. Set its new name if required to identify the network by its subnet. Apply the change and press OK.
NOTE: Please double-check that cluster communication is configured with redundant networks:
https://docs.microsoft.com/en-us/windows-server/failover-clustering/smb-multichannel
2. Rename other networks as described above, if required.
3. In the Actions tab, click Live Migration Settings. Uncheck the synchronization network, while the iSCSI network can be used if it is 10+ Gbps. Apply the changes and click OK.
live migration
The cluster configuration is completed and it is ready for virtual machines deployment. Select Roles and in the Action tab, click Virtual Machines -> New Virtual Machine. Complete the wizard.
Configuring File Shares
Please follow the steps below if file shares should be configured on cluster nodes.
Configuring the Scale-Out File Server Role
1. To configure the Scale-Out File Server Role, open Failover Cluster Manager.
2. Right-click the cluster name, then click Configure Role and click Next to continue.
StarWind Configuring Server Roles
3. Select the File Server item from the list in High Availability Wizard and click Next to continue.
4. Select Scale-Out File Server for application data and click Next.
Select Server Type
5. On the Client Access Point page, in the Name text field, type the NetBIOS name that will be used to access a Scale-Out File Server.
StarWind File Server Name
6. Check whether the specified information is correct. Click Next to continue or Previous to change the settings.
File Server Confirmation
7. Once the installation is finished successfully, the Wizard should now look like the screenshot below.
Click Finish to close the Wizard.
File Server Summary
8. The newly created role should now look like the screenshot below.
NOTE: If the role status is Failed and it is unable to Start, please, follow the next steps:
FIle Server Error
  • open Active Directory Users and Computers
  • enable the Advanced view if it is not enabled
  • edit the properties of the OU containing the cluster computer object (in this case – Production)
  • open the Security tab and click Advanced
  • in the appeared window, press Add (the Permission Entry dialog box opens), click Select a principal
  • in the appeared window, click Object Types, select Computers, and click OK
  • enter the name of the cluster computer object (in this case – Production)
Select User. Computer
  • go back to Permission Entry dialog, scroll down, and select Create Computer Objects,
Permission Entry for Computers
  • click OK on all opened windows to confirm the changes
  • open Failover Cluster Manager, right-click SOFS role and click Start Role
To Add File Share:
  • expand the cluster and then click Roles
  • right-click the file server role and then press Add File Share
  • on the Select the profile for this share page, click SMB ShareApplications and then click Next
SMB Share
5. Select a CSV to host the share. Click Next to proceed.
Selecting server for share
6. Type in the file share name and click Next.
Spacify Share name
7. Make sure that the Enable Continuous Availability box is checked. Click Next to proceed.
Configuring share settings
8. Specify the access permissions for the file share.
Permissions to Control Access
NOTE:
  • for the Scale-Out File Server for Hyper-V, all Hyper-V computer accounts, the SYSTEM account, and all Hyper-V administrators must be provided with the full control on the share and file system
  • for the Scale-Out File Server on Microsoft SQL Server, the SQL Server service account must be granted full control on the share and the file system
9. Check whether specified settings are correct. Click Previous to make any changes or click Create to proceed.
Confirm Selections SOFS
10. Check the summary and click Close to close the Wizard.
SOFS results
To Manage Created File Shares:
  • expand the cluster and click Roles
  • choose the file share role, select the Shares tab, right-click the created file share, and select Properties:
Failover Cluster manager Shares
Configuring the File Server for General Use Role
NOTE: To configure File Server for General Use, the cluster should have available storage
1. To configure the File Server for General Use role, open Failover Cluster Manager.
2. Right-click on the cluster name, then click Configure Role and click Next to continue.
4. Select File Server for general use and click Next.
File Server Type
5. On the Client Access Point page, in the Name text field, type the NETBIOS name that will be used to access the File Server and IP for it.
File Server Client Access Point
6. Select the Cluster disk and click Next.
Select Storage
7. Check whether the specified information is correct. Click Next to proceed or Previous to change the settings.
File Server General Use Confirmation
8. Once the installation has been finished successfully, the Wizard should now look like the screenshot below.
File Server Summary
9. The newly created role should now look like the screenshot below.
File Server
  • open Failover Cluster Manager, right-click File Share role and click Start Role
Configuring SMB File Share
To Add SMB File Share
1. Open Failover Cluster Manager.
2. Expand the cluster and then click Roles.
3. Right-click the File Server role and then press Add File Share.
4. On the Select the profile for this share page, click SMB ShareQuick and then click Next.
Profile for SMB Share
5. Select available storage to host the share. Click Next to continue.
Server and path for share
Share Name
7. Make sure that the Enable Continuous Availability box is checked. Click Next to continue.
Configure share settings
8.Specify the access permissions for the file share.
Permissions
9. Check whether specified settings are correct. Click Previous to make any changes or Next/Create to continue.
Confirmation
10. Check the summary and click Close.
View results
To manage created SMB File Shares
11. Open Failover Cluster Manager.
12. Expand the cluster and click Roles.
13. Choose the File Share role, select the Shares tab, right-click the created file share, and select Properties.
Failover cluster settings
Configuring NFS file share
To Add NFS File Share
4. On the Select the profile for this share page, click NFS Share – Quick and then click Next.
Profile for this share
Share Name
7. Specify the Authentication. Click Next and confirm the message in pop-up window to continue.
Autentication method
8. Click Add and specify Share Permissions.
Share Permissions
Add Permission
9. Specify the access permissions for the file share.
Permissions
10. Check whether specified settings are correct. Click Previous to make any changes or click Create to continue.
Confirm Selections
11. Check a summary and click Close to close the Wizard.
NFS Share results
To manage created NFS File Shares:
  • choose the File Share role, select the Shares tab, right-click the created file share, and select Properties
Deploying and configuring Failover Cluster on Microsoft Azure Stack HCI is a crucial process for organizations looking to achieve a high-performing, VM-centric environment. With this guide, IT professionals will have all the necessary resources for a successful cluster deployment with a shared highly-available storage, provided by StarWind VSAN.
