Appliance
for Enterprise ROBO,
SMB & Edge
StarWind Virtual SAN: Feature Configuration Guide for Scale Out on VMware vSphere [ESXi]
Annotation
Relevant products
StarWind Virtual SAN (VSAN)
Purpose
This document outlines how to reconfigure existing 2-node Hyperconverged setup with VMware vSphere by adding an additional node into configuration and getting a 3-node configuration with 2-way active-active StarWind VSAN replication. It’s assumed that StarWind HA devices (DS1 and DS2) and corresponding datastores are already created. One more StarWind HA device will be added as a part of reconfiguration and corresponding datastore (DS3) will be created in VMware vSphere.
Audience
This technical guide is intended for storage and virtualization architects, system administrators, and partners designing virtualized environments using StarWind Virtual SAN (VSAN).
Expected result
The end result of following this guide will be a fully configured 3-node high-availability ESXI-based setup.
Prerequisites
StarWind Virtual SAN system requirements
Please read the StarWind Virtual SAN Best Practices document for additional information:
Solution diagram
The idea behind scale-out is to grow both storage and compute power by adding additional nodes instead of adding disks, CPUs, NICs, or RAM to individual systems.
The diagram below illustrates the network and storage configuration of the 2-node Hyperconverged Scenario with VMware vSphere. The article on how to deploy a 2-node Hyperconverged Scenario with VMware vSphere could be found at the link below:
https://www.starwindsoftware.com/resource-library/starwind-virtual-san-vsan-configuration-guide-for-vmware-vsphere-esxi-7-vsan-deployed-as-a-controller-virtual-machine-cvm-using-web-ui/
The diagram below illustrates the resulting network and storage configuration of the 3-node deployment with 2-way active-active StarWind VSAN replication:
2. StarWind VSAN should be installed on the Windows Server operating system deployed as VM on each host.
3. The hosts should have additional network interfaces to the connection the Host 2 to the Host 3 and the Host 1 to the Host 3 for iSCSI and Heartbeat traffic.
4. On each node, network interfaces to be used for Synchronization and iSCSI/StarWind heartbeat should be in different subnets and connected directly according to the network diagram above. Here, the 172.16.10.x, 172.16.11.x, 172.16.12.x subnets are used for the iSCSI/StarWind heartbeat traffic, while the 172.16.20.x, 172.16.21.x, 172.16.22.x subnets are used for the Synchronization traffic.
NOTE: Do not use ISCSI/Heartbeat and Synchronization channels over the same physical link. Synchronization and iSCSI/Heartbeat links can be connected either via redundant switches or directly between the nodes.
Replacing Partner for DS2 Virtual Disk
1. Open StarWind Management Console and add the third StarWind server(SW3), which was previously deployed.
Add new StarWind Server
2. Open Replication Manager for DS2 device on the second StarWind node.
3. Click Remove Replica. The replica to the first node (SW1) will be removed.
StarWind Replication Manager
4. Click Add Replica.
5. Select Synchronous “Two-Way “Replication and click Next.
6. Enter Host Name or IP Address of the third StarWind node.
7. Select Create new Partner device.
8. Select Synchronization Journal Strategy and click Next.
Synchronization_Journal_Setup
9. Click Change Network Settings. Specify the interfaces for Synchronization and Heartbeat channels. Click OK. Then click Next.
StarWind Interfaces
10. Click OK to return to Network Option for Synchronization Replication. Click Next.
11. Click Create Replica.
12. After creation, click Finish to close the Replication Wizard. The result should look as shown in the screenshot below.
Creating Virtual Disk DS3
1. Select SW3 server and open Add Device wizard by right-clicking the StarWind server and selecting Add Device (advanced) from the shortcut menu or by clicking the Add Device (advanced) button on the toolbar.
2. Once Add Device wizard appears, follow the instructions to complete the creation of a new disk, which will be replicated to SW1 server.
3. Select Hard Disk Device as the type of a device to be created. Click Next to continue.
4. Select Virtual Disk. Click Next to continue.
5. Specify virtual disk location and size.
StarWind add device
6. Specify Virtual Disk Options and click Next to continue.
NOTE: Sector size should be 512 bytes when using ESXi.
7. Define the RAM caching policy and specify the cache size in the corresponding units if required.
 8. Define the Flash caching policy and the cache size. Click Next to continue.
 9. Specify Target Parameters. Select the Target Name checkbox to enter a custom name of the target if required. Otherwise, the name will be generated automatically in accordance with the specified target alias. Click Next to continue.
10. Click Create to add a new device and attach it to the target and Finish to close the wizard.
11. Right-click on the recently created device and select Replication Manager from the shortcut menu.
12. Click Add replica and select Synchronous “Two-Way Replication”.
13. Specify partner Host Name (SW1) or IP address and Port Number.
14. Select Create new Partner Device and click Next.
15. Select Synchronization Journal Strategy and click Next.
16. Click Change Network Settings.
StarWind Interfaces for Synchronization Channels
16. Click Create Replica.
17. The added devices are seen in the StarWind Console.
StarWind management Console
Creating Datastores
1. Open the Storage tab on one of the hosts and click on New Datastore.
Creating datastore
2. Specify the datastore name, select the previously discovered StarWind device, and click on Next.
Select Device
3. Enter datastore size. Click on Next.
Partitioning Options
4. Verify the settings. Click on Finish.
New Datastore
5. Add another datastore (DS2) in the same way but select the second device for it.
6. Verify that storage (DS1, DS2) is connected to both hosts. Otherwise, rescan the storage adapter.
Datastores
7. Path Selection Policy changing for Datastores from Most Recently Used (VMware) to Round Robin (VMware) has been already added into the Rescan Script, and this action is performed automatically. For checking and changing this parameter manually, the hosts should be connected to vCenter.
8. Multipathing configuration can be checked only from vCenter. To check it, click the Configure button, choose the Storage Devices tab, select the device, and click on the Edit Multipathing button.
Configure MPIO
Round Robin
Performance Tweaks
Advanced Settings
Disk.DiskMaxIOSize
NOTE: In certain cases, in Virtual Machine, Windows event log may report an error similar to “Reset to device, \Device\RaidPort0, was issued”. Check this KB acticle for a possible solution.
Following this guide, the existing 2 node ESXI -based cluster was reconfigured and the 3d node was added. As a result, the cluster was extended and got more available space for storing highly available virtual machines.
