StarWind rPerf: A super-handy free tool to ensure your RDMA network connections are running at their full speed
Tweet |
[Middleton, MA, October 2nd] StarWind, a leading provider of hyperconverged IT infrastructure for SMB and ROBO presents its brand new RDMA performance benchmarking utility, StarWind rPerf.
StarWind rPerf is a unique asset for system administrators helping to ensure RDMA network connections are running at their maximum performance level. The tool measures both latency and bandwidth for RDMA connections between different operating systems such as Windows Server and various Linux. Being a reliable connection metrics utility, StarWind rPerf has numerous benefits:
Free: The utility can be used completely at no cost.
Simplicity and Easy to Use: StarWind rPerf is the only tool allowing to measure both latency and bandwidth for cross-platform RDMA connections.
Time-saving: The tool is very easy to use, and it allows finding all the information required with just a few simple commands, thus minimizing the time spent on numerous diagnostics and tests.
About StarWind
StarWind is a virtualization pioneer focused on delivering Software-Defined Storage and HyperConverged Infrastructure solutions designed to build high-performing, flexible, and resilient IT infrastructures for SMB and ROBO. Founded in 2009, StarWind has spread remarkably over the globe and helped to build virtualization infrastructures for over 140,000 free users and more than 4,000 paying customers around the world.
