To set up the witness node, perform the following actions:
Witness node works only with Node Majority Failover Strategy.
1. Create a new device. To create the new device, use the guide at the following link:
Creating a New Image File Device
2. Right-click the required device and select Replication Manager from the shortcut menu. Then, click Add Replica.
3. Select Synchronous "Two-Way" Replication as a replication mode.
4. Click Next to proceed.
5. Specify a partner hostname, IP address, and port number.
6. Click Next.
7. Select Node Majority and click Next.
8. Select Partner device setup and click Next.
9. You can modify the target name if required. Click Next.
10. Select Synchronization Journal Strategy and click Next.
There are several options – RAM-based journal (default) and Disk-based journal with failure and continuous strategy, that allow to avoid full synchronization cases.
11. Click Change network settings.
12. Specify the interface for Synchronization and Heartbeat channels.
13. Click Next.
14. Click Create Replica.
15. The successfully added devices appear in the StarWind Console.
16. Right-click the required device and select Replication Manager from the shortcut menu. Then, click Add Replica.
17. Select Witness Node replication as a replication mode.
18. Click Next to proceed.
19. Specify a partner hostname, IP address, and port number.
20. You can modify the target name if required. Click Next.
21. Click Change network settings.
22. Specify interfaces for the synchronization channel.
23. Click Create Replica.
24. Click Close to close the wizard.
25. The successfully added devices appear in the StarWind Console.
